View Full Version : best prices on TKO-600?
cakneller
04-21-2005, 10:35 AM
Does anyone know of a good place to get a deal on a tko-600 for a camaro swap?
70CaliCustom
04-21-2005, 12:14 PM
Check out www.classicchevy5speed.com . I've heard a lot of good things about them and hopefully I'll be buying a TKO from them this summer.
Hurst – Scott
04-21-2005, 02:34 PM
70CaliCustom:
Thanks for the nice reference to our web site. Jeff and I were just talking about doing a group purchase for Pro Touring. Group purchase would get free shipping on TKO when they buy one of our deluxe kits ($95 savings).
Give us a call if you are interested, we will limit it to 5 kit sales. Call us at (760) 230-2045 for details.
Thanks, Scott
www.ClassicChevy5Speed.com (http://www.classicchevy5speed.com/)
whytry
04-21-2005, 02:49 PM
I got mine from them and I have no complaints!!! Jeff was a great resource for me to bounce install questions off of. I would definitely recommend them!!!
bxm196
04-21-2005, 04:37 PM
Do you need to cut the trans tunnel to get the tko from www.classicchevy5speed.com (http://www.classicchevy5speed.com) to fit in a 1969 Camaro and will it work with the console in the stock location?
Hurst – Scott
04-21-2005, 05:08 PM
No tunnel modifications are needed for Camaro swap. You will have to trim 2" or so from right hand corner (if you have 4 speed) of stock tranny hole in your floor. Other than that, that is only trim that is needed. Standard TKO shifter will pop up in stock console postion. Here's a link that will give you more installation notes/info:
67 to 69 Camaro:
http://www.classicchevy5speed.com/67_69_camaro_transmission_install_notes.htm
Let us know if you have any addtional questions.
Thanks, Scott
PH: (760) 230-2045
apex69
04-22-2005, 02:49 AM
D&D Performance had a screaming deal in March with free shipping. And like the wiz, "nobody beats em".
www.ddperformance.com
cakneller
04-22-2005, 02:21 PM
thanks for the info. ClassicChevy5Speed.com is a great site.
I'm interested if anyone is going to do a group purchase.
Hurst - Jeff
04-22-2005, 09:38 PM
cakneller,
Thanks for the compliment - we work hard to keep our website up-to-date and informative. Give us a call to kick off the group purchase.
68driver
05-19-2005, 06:42 AM
I'm also considering an upgrade to the TKO 5-speed. What can I re-use from my exisitng setup? I'm currently running the original 3-speed manual transmission (console shifter), 153 tooth flywheel, and 10.5 clutch assembly in my 68 Camaro. The engine is a 383 with "internally balanced" crank. Can I use my existing bellhousing, flywheel, etc...?
Rob C.
Hurst - Jeff
05-19-2005, 07:54 AM
You can use your existing clutch linkage and bellhousing. You will need to change your clutch disc toa 26 spline.
Click to here to take a look at a kit the will give you just about everything you will need: http://www.classicchevy5speed.com/Deluxe_Transmission_Kit.htm.
Feel free to call with questions.
68driver
05-19-2005, 11:20 AM
You can use your existing clutch linkage and bellhousing....
Thanks Jeff.
Just to confirm... I can use my 153 tooth flywheel?
I'm probably a few months away, but this will really help get my plans organized.
Thanks again,
Rob C.
Hurst - Jeff
05-21-2005, 10:18 PM
Yes, you can use your 153 tooth flywheel.
