View Full Version : 68 camaro driver/autocross/road race
My dream car is finally being built! Screamin Performance is doing the build for me while I am overseas. Many thanks to Brian (owner of Screamin Performance) for doing such great work and making this build pain free!!
Chassis/Suspension:
Stock sub media blasted, factory welds ground down and rewelded
ATS Chicane coilover brackets
AFX tall spindles
GW UCA's
GW LCA's
Bilstein coilovers, Hyperco springs
Hotchkis sway bar
DSE stock height body mounts
GW L2 Leafs, Bilstein HD shocks
DSE weld in SFC's
Wheels/Tires/Brakes/Steering:
Forgeline zx3r, 17x8, 17x9.5
Toyo r888, 245/40/17, 275/40/17
Wilwood 7/8 master, prop valve
New hard lines fabricated by Brian
Kore3 c5 zo6 brakes with parking brake, braided lines
ATS Lee 670 gear
Moog inner tie rods, pitman, rag joint
Baer tracker outer tie rods
Engine/Trans:
383 stroker, al heads, air gap, holley carb
New msd ignition system
Dougs d368 1 3/4 headers, 3" dr gas x, 3" borla xr-1 dumped
T56 magnum kit from Hurst
Ron Davis al. rad and el. fans
Canton high rpm v belt pulley system
This basically phase 1. There will be a phase 2 in which the engine will become a solid roller with AFR 210 eliminators, Roll cage, maybe a nice stereo.... Yada yada
Brian will chime in here and post pics of the build. But you can also see her come along here.
http://www.jaclynsuzann.com/screaminperformance/gallery/Current%20Projects/Chris's%2068%20Camaro/index.html
67speedfreak
02-06-2010, 12:03 AM
Chris,
It's been a pleasure. Here are some pics of the progress so far.
Original sub was tweaked.
Replacement sub blasted and welded up.
67speedfreak
02-06-2010, 12:15 AM
ATS Chicane coilover brackets welded in.
Sub primed and painted.
67speedfreak
02-06-2010, 12:23 AM
Front suspension and brakes installed.
67speedfreak
02-06-2010, 12:29 AM
Rear end cleaned ,painted and Kore3 brake kit installed.
Dalamar
02-06-2010, 01:51 AM
those are some great looking upgrades!
MCMLXIX
02-06-2010, 03:12 AM
Looks good. Are you going to paint the rear calipers to match?
Will the interior remain stock?
What about wheels and tires?
Looks like a great car to start with...
CruizinKev
02-06-2010, 04:03 AM
very nice! :twothumbs
Interior will get sparco evo2+ seats, 4 point cage, crow harnesses. Guages will be upgraded to autometer when trans is put in. I'm trying to keep this car as basic as possible. If it can stay manual or mechanical I want it that way. Nothing fancy! Wheels are being built right now, 17" forgeline zx3r's
sik68
02-06-2010, 09:42 AM
Dolf! It's awesome! Our cars are going to be clones from head to toe. Fixed back seats, check. 4 pt bars, very soon check. R888s, very soon check (they will be my reward if I can ever get good enough to outdrive the eagle f1GSD3's I have).
As for the frame connectors, I have a pair of bolt in ones I haven't installed yet. Not ready to go weld-in yet because I will probably remove my subframe a couple times eventually.
Where do you live? It would be awesome to be able to compare an identical car coilover vs non coilover to see what the differences are. I want that penske / chicane kit real bad now!
Subscribed, good luck!
Steven, good to see ya in here bro. I live on Merritt Is. Florida so i'm not sure if we will ever get to do a side by side comparo. I'll def be keeping you updated on the cars performance though. I'm trying to figure out which sparcos seats to get. I am 5'11'' 205, broad shoulders. I think I am in between the evo2+ and the evo 3's. Prob go 3's for more DD comfort. Can't wait to rip on her when I get home!!
sik68
02-08-2010, 08:16 AM
My dad is 5'9" 195, 34 waist with a broad build, and he can fit into my Pro2000 seat snugly but without discomfort...I think it's about the same measurements as the Evo2. I called Sparco for their advice on seats and they were actually really helpful and patient...I think I talked to a guy named Warren IIRC, who knew his stuff. Evo 3 would probably be a safe bet....even if it's a smidge too wide, the lumbar pads will hold you in.
I don't know what passenger seat to get...not another Pro2000...I'll probably get a Evo2 so I don't hear so many complaints about being hard to get in/out of.
DYNODANNY
02-08-2010, 08:28 AM
My brother has a 68 camaro that I'm triying to convince to bring to the 21st. century. Keep up the good work.
Ordered a Ron Davis radiator setup tonight! Stoked! Dual 13" fans and an integrated overflow tank. I love the fabbed aluminum look!
796spdbu
02-08-2010, 02:51 PM
Dolf,My bro lives around Merritt Island. I'd like to check your car out when its finished. Looks like its coming along quickly!!
Well I am currently overseas but the car is at Screamin Performance on Merritt Is. If you would like to stop by and see the progress in it's current state i'm sure Brian won't mind. He has some SICK other projects going on there as well. I will be coming home late apr and we can meet up then too.
OH!! I likey so far :cool: keep going lets see some more
sebtarta
02-09-2010, 03:59 AM
That looks really good.
What rotors are you using?
Stock C5 durastop rotors. Most of the serious track guys on corvetteforum say you go through rotors so fast that it's a waste to use expensive ones. Just rock some track pads and you're good to go. Once I get the car on the road course I have some ideas for brake cooling ducts.
67speedfreak
02-17-2010, 11:49 AM
The new steering box showed up along with the rest of the steering components.
Got them installed and put the sub back under the car.
Lookin good!
Motown 454
02-17-2010, 06:28 PM
Nice work Brian it looks great. Is that a Lee's steering box?
Steve1968LS2
02-17-2010, 06:31 PM
Nice project.. it's good to see stock subframes still getting the love.
6spdcamaro
02-17-2010, 06:38 PM
You may want to double check that master cylinder. When i talked to tobin he recommended a 15/16-1" bore master with 8-9" dual boosters like the one detroit speed has. I don't know if the wilwood will work with the c5 brakes. I've been wrong before (i usually am lol) but the master is very important in the performance of the brake kit. Good luck, looks like a cool project.
Yes, Lee manufacturing box. -6 line from the pump to the box. -6 to and external Canton reservoir. -10 feed back to pump. If I start to experience over heating I will install a cooler.
Thanks. This is a 7/8 master. I talked with Tobin and he reccommended this for the manual c5 setup.
6spdcamaro
02-18-2010, 12:15 PM
Ohhhh manual, well that changes things. My bad lol
Motown 454
02-18-2010, 12:34 PM
dolf Sweet project.
67speedfreak
03-01-2010, 06:58 AM
Couple pics of parts that came in. Sweet !
Mocking up motor and new T56 magnum. We have to rise the tunnel for clearance.
Rear is back in the car.
John Wright
03-01-2010, 07:04 AM
Coming right along!
Bryce
03-01-2010, 08:04 AM
looking good!
nickpro_c10
03-01-2010, 09:23 AM
Car looks great man... Where are you at Overseas?
I am doing contract firefighting in Iraq right now. Al Taqaddum and Al Asad FOB's.
67speedfreak
03-17-2010, 09:10 PM
Here is a little update.
Clearancing tunnel for the t-56.
We found some sneaky fiberglass work on the drivers side floor pan and toe board so we had to cut it out.
After sealing up the inner support we welded in the toe board patch.
jreut703
03-18-2010, 04:04 AM
car looks great coming along good luck will be watching the build
ProdigyCustoms
03-18-2010, 04:47 AM
We got a little jewelry coming to our place for ya. I got to run to Melbourne Saturday. I could drop them off.
Frank, that would be a huge help sir. PM sent
67speedfreak
03-18-2010, 05:38 AM
Frank,
That would be great. Give me a call and let me know when your coming.
Brian
FoxGranadaChuck
03-18-2010, 05:56 AM
Thank you so very much for your service to our country!!
ProdigyCustoms
03-18-2010, 06:03 AM
Frank,
Brian
It is going to be one of those mass coordination efforts. but I am working out the details.
67speedfreak
03-18-2010, 04:15 PM
We got the floor pan welded in today.
ProdigyCustoms
03-19-2010, 12:52 PM
The wheels are here, the wheels are here, the wheels are here!
I will swing by in the morning guys
Polished lips and silver centers, very sharp!
Notice the lightening holes on the backside of the rce wheels. And as with all our wheels, even the race wheels get FREE powder coat inners.
67speedfreak
03-19-2010, 06:08 PM
They look great !
We'll see ya Tomorrow.
67speedfreak
03-19-2010, 06:15 PM
We finished the tunnel mods today.
We just need to epoxy and seam seal.
We should have it back on the wheels next week !
Gitter Dun
03-19-2010, 09:19 PM
Nice work, looks like your running Toyo R888, I still need to scrub mine in but so far I am still liking the RA-1's better.
Bad94
03-20-2010, 04:41 PM
Whos clutch master cylinder bracket is that?
70ssracer
03-21-2010, 12:57 PM
where can I buy some of these coilover brackets? I've looked in the vendor section and maybe I just over looked them
It is included in the hydraulic clutch kit from Hurst. Available as an option with the t56 magnum
70SSracer they are from ATS/ speedtech. They are sponsors on the site. T56kit.com
67speedfreak
03-23-2010, 06:55 PM
So we got the floor and tunnel all sealed up.
We also managed to get the sub and the motor back in.
Here is a shot of the new Wheels.
I was worried about the wheelsbut they look SICK! Thanks Frank and Brian for all the hard work! 30 days untill she gets ripped on!
Dalamar
03-24-2010, 08:32 AM
agreed, those wheels look good on the car!
Smock67
03-24-2010, 03:51 PM
You Camaro is coming along great. The wheels really set it off. Might have to make a trip on over to this since im kinda close.
Gitter Dun
03-25-2010, 10:12 AM
Wow, nice build Dolf, and definitely the wheels I'm going with when the time comes, If it is not to late and you haven,t already done so, I would consider a Canton road racing oil pan and or an accusump system depending on how much roadracing you are going to do. Especially if you are running a high volume oil pump. I headed into the middle of turn 2 at Infineon at about 7300 RPM, sucked my pan dry, and through a rod bearing. I think If I had the Canton oil pan at that time this would not have happened.
Gitter Dun
03-25-2010, 10:30 AM
One more thing I forgot to mention, get a power steering pump that will stand up to the abuse of road racing, I am using a KRC aluminum unit with seperate reservoir, they are very light weight and so far in 8 years I have had it, no complaints. What about the engine oil cooler. I am using a Setrab unit and had it custom mounted behind the front grill, I also incorporated a MOCAL 180 degree oil thermostat so that the cooler will be bypassed under those temperatures, all oil running through 12 an steel braided lines. System One remote oil filter, mounted behind front grill also.
67speedfreak
03-25-2010, 08:41 PM
Here is a teaser of the wheels. And yes I know they are on the wrong side. I have studs and lugs on order, Will be here tomorrow.
Trans is in, Along with the headers.
gregamanda
03-28-2010, 06:49 AM
What P/N headers are these? Looks tight on the steering gearbox. Did they clear without having to modify? I am building the same car now. 68 all black, 383 with lots of DSE equipment. I live in Mooresville, NC (same as DSE) so it is too easy to go over there for the parts. Anyway, I like the build. Brian is doing great. I am close to needing headers now.
gregamanda
03-28-2010, 06:58 AM
Sorry dolf, just saw on page #1 of the post your details and the headers are Doug's. Cancel last post. Thanks.
1971CHEVELLE
03-28-2010, 06:59 AM
:1st: Awesome car
67speedfreak
03-31-2010, 06:55 PM
Little update.
Putting front end back together.
sik68
04-01-2010, 07:33 AM
Looking great! I'm jealous that your car will be on the road before mine will though...
SIK02SS
04-01-2010, 10:57 AM
great project!
how much "road racing" are you looking to do with the car? How hard will you be pushing the car (or stopping it)? Do you have a curb weight for the car?
I race with SCCA in a C5Z06, and the factory brakes really aren't great. The C5 calipers spread after a few weekends, and the rotors go fast. Just something to think about :)
great project!
I will be doing a couple HPDE's when I can mostly at sebring. I will not be pushing the car 10/10th's! I am just getting the car to a starting point right now. Eventually when I get everything sorted out on the autocross course I will start road racing. At that time I will be adding front brake cooling ducts to help out. Prob use stock c5 rotors because they are going to go fast anyways and play with different pad combos.
SIK02SS
04-02-2010, 09:02 AM
cool. you'll have a lot of fun regardless!! :)
67speedfreak
04-12-2010, 09:01 PM
We are getting close now.
Hope to have it driving by the end of the week.
sebtarta
04-13-2010, 06:03 AM
wow. that looks so clean!
Steve68
04-13-2010, 08:01 AM
great project!
That right there is some great info!!!
guys the car looks great,
Brian, how does Dio always make it in the pics?? he the shop photo bomber!!!!!
67speedfreak
04-13-2010, 08:44 AM
That's to funny! Dio is a ham, when ever I get the camera out he follows me around.
67speedfreak
04-13-2010, 06:20 PM
We finished the exhaust today.
We are down to wiring and plumbing.
sik68
04-13-2010, 08:21 PM
It would be great to hear some audio of the exhaust..as I also have the D368 headers, Borla XR-1's with the Magnaflow X pipe, dumped before the axle. I have the parts, just not installed yet.
Dolf where are you getting your parts ideas?! Haha
Steven, I will admit Trackday has been an inspiration for me. I am using a Dr. Gas x pipe though. So our cars are not 100% identical. LOL
If Brian can't get a sound clip, I will see if I can when I get home
sik68
04-13-2010, 10:31 PM
Haha, don't get me wrong I am happy that my writeups get put to good use. Besides this whole pro touring thing is so niche, we're all "inspiring" each other anyways. :). I hope you have a blast with it! Can't wait for you to get it out there! I hope to take ~70 lbs off the front end in the next couple months...we'll see!
Steven
DYNODANNY
04-14-2010, 09:24 PM
progress! man your ride is looking sweet. My brother has been putting in alot of work on his 68, he just joined the forum.
67speedfreak
04-15-2010, 04:21 AM
We put her on the ground. We still need to adjust ride height.
The front will come up a little.
John Wright
04-15-2010, 04:22 AM
It's good to see it back on all fours again...good job!
Dons67
04-15-2010, 05:19 AM
i'd love to hear that too - I'm not overly thrilled with my flowmasters but i can't have anything too loud as the kids ride in the car a lot - - i would love to hear this set up
ps - car is looking great! - don
67speedfreak
04-19-2010, 08:31 PM
OK, She lives !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!
CHECK OUT THE VIDEO HERE !
http://www.youtube.com/watch?v=89iwtnGx_ME
67speedfreak
04-19-2010, 08:58 PM
Couple more pics.
dlouie87
04-19-2010, 09:21 PM
what battery tray is that? fesler?
SIK02SS
04-20-2010, 08:37 AM
Nice!!
67speedfreak
04-25-2010, 08:42 AM
Well we got her all finished up for now.
Waiting on Chris to pick her up.
I'm real happy with the way it turned out. She Screams. We added one of our Carbon front spoilers.
67speedfreak
04-25-2010, 08:44 AM
Jarcaines
04-25-2010, 09:00 AM
This is easily one of my favorite projects on here. Love everything about this car, it's basically what I want to do to mine.
Gitter Dun
04-25-2010, 05:43 PM
Congratulation's, Great Build!!
John Wright
04-26-2010, 03:34 AM
Very nice!....he's gonna love it.
KlasSic68
04-27-2010, 07:16 AM
Nice build, should be a blast to drive. Sounds pretty mean too!
HOLY CRAP! Where do I start guys. This car is wayyy past where I thought we were going to be! I can't believe a 68 can handle like this does and we haven't even begun to push it. The engine sure liked the tune up and new ignition/ exhaust! Doesn't feel or sound like the same one. SERIOUS power... and we are not done yet. I have AFR elims on the shelf waiting. I haven't updated you guys because I literally can't get out of the car. I need Brian to install a laptop in her to keep my fellow pro-tourers up to date. BIG thanks to Brian and Anthony at Screamin Performance! I know you guys will be track side with me soon waiting for your turn to rip on her.
John Wright
04-29-2010, 12:00 PM
^^^^that's what I wanted to hear!
Quit typing and...Get back out there and enjoy that car.
sik68
04-29-2010, 01:21 PM
Very cool Dolf! I know the feeling. The car does handle unbelievably well. It will make a world of difference getting better seats in there too. You'll feel way more planted, giving your hands the ability to work the wheel rather than using your hands on the wheel to hold you in place. Kick the crap out of those Toyo's already!
Couple changes have been made to the car. Brian will be posting pics soon. Cage, seats, brakes...etc
67speedfreak
07-25-2012, 08:51 AM
https://static1.pt-content.com/images/pt/2012/07/IMG_4039JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_4052JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6428JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6426JPG-1.jpg
67speedfreak
07-25-2012, 08:56 AM
https://static1.pt-content.com/images/pt/2012/07/IMG_6420JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6397JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6388JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6389JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6381JPG-1.jpg
67speedfreak
07-25-2012, 09:03 AM
https://static1.pt-content.com/images/pt/2012/07/IMG_3445JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_6329JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8082JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8086JPG-1.jpg
67speedfreak
07-25-2012, 09:07 AM
https://static1.pt-content.com/images/pt/2012/07/IMG_7971JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_7976JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_7977JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_7983JPG-1.jpg
67speedfreak
07-25-2012, 09:09 AM
https://static1.pt-content.com/images/pt/2012/07/IMG_8088JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8090JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8089JPG-1.jpg
Tango68SS
07-25-2012, 12:08 PM
Let me tell you guys... Chris' car is "Bad-to-the-bone"!! It was/is the inspiration for a lot of the things I had Brian do to my baby! ... now if we can just convince Chris to go with an LSx set-up!! :smoke:
makoshark
07-25-2012, 12:43 PM
What length/stroke coil-over did you use on the front and what length spring? I am building the same setup and am having difficulty working out the correct length
joeelutz
07-25-2012, 04:51 PM
Did you make that package tray or is that something that you bought and modified? I would like to get one of those.
Sorry my man, nothing but old school belongs under my hood! I am ha ving my new engine built right now, 440" sbc with 15 degree heads. 800hp on pump! Should be a good time
I don't know. I actually just wrote Tyler this week to find that out for myself but he said all of his notes have been given to Speedtech. I'd call them to find that out.
makoshark
07-25-2012, 11:23 PM
I did call Speedtech and was told to run a 5" stroke coil-over with 10" springs. Tyler just confirmed that with me as well as James of the OLC Camaro. My measurements and calculations are coming out to fit that particular coil-over, but Ridetech is telling me otherwise. I see where they are coming from, but the #'s and what others have done don't lie. I love Ridetech's products and customer service, so I am in no way trying to give any negativity about them. I just don't think they are hugely familiar with this particular setup.
Never tried Ridetech shocks but I have used Blsteins on all of my cars and all have been amazing. I am a Bilstein shock guy for life. Can't go wrong with a company that specializes in their product.
makoshark
07-25-2012, 11:42 PM
I've run Bilsteins on all my vehicles as well. They make an amazing shock, for sure. I would imagine that if I used Bilstein coil-overs I would be equally happy, but this time around I purchased the new Ridetechs. They spec'd me a shorter coil-over for the front, which I already bought, but they just won't fit this particular setup. I have not used them yet, so Ridetech is willing to swap them out, for me, to whatever size I actually need. They are truly one of the best companies I have ever dealt with.
You can purchase on here... http://screaminperformance.com/product.htm
I am also using his hood latch, kick panels, front carbon spoiler, and gauge mount. Highly recommend all of them!
67speedfreak
07-26-2012, 05:41 PM
https://static1.pt-content.com/images/pt/2012/07/IMG_8093JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8284JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8285JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8287JPG-1.jpg
67speedfreak
07-26-2012, 05:44 PM
https://static1.pt-content.com/images/pt/2012/07/IMG_8264JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8265JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8270JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8272JPG-1.jpg
67speedfreak
07-26-2012, 05:48 PM
https://static1.pt-content.com/images/pt/2012/07/IMG_8266JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8267JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMG_8269JPG-1.jpg
Ron.in.SoCal
07-26-2012, 07:08 PM
Great car Dolf!
Tango68SS
07-30-2012, 12:10 PM
Yeah, Brian told me... I can't wait one of these days to meet you in person and go with you to an event! I've got to see your ride in action!
TC
67speedfreak
08-02-2012, 06:18 PM
https://static1.pt-content.com/images/pt/2012/08/IMG_8323JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_8327JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_8337JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_8339JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_8340JPG-1.jpg
67speedfreak
08-02-2012, 06:20 PM
https://static1.pt-content.com/images/pt/2012/08/IMG_8341JPG-1.jpg
https://static1.pt-content.com/images/pt/2012/08/IMG_8344JPG-1.jpg
Sat the 25th there is an autocross at Central Florida Racing Complex in Orlando. I will be there racing the car as well as Brian. Anyone else want to go and get some let us know. This is no ordinary autocross though, this called crooked drags. Line up like a drag race and race the opposing vehicle on mirrored autcross courses, first one back wins. Bad assery ensues!
Tango68SS
08-23-2012, 03:50 AM
Brian called me yesterday to let me know... What time? Also, is that the complex on the west side of Orlando Intl??
TC
http://cfracingcomplex.com/contact-us/
TC, yes, near the airport. Come out and represent old school muscle against Euros and imports!
Flash68
09-26-2012, 02:07 PM
Gitter dun Dolf!
