View Full Version : ls2 accessory drive for 72 chevelle
dropped72ss
01-31-2010, 03:55 PM
I want to swap a 06 ls2 in my chevelle its out of a trailblazer. Will the accessory drive work under my stock hood? If not what's needed to make it work? New brackets or what? Thanks
ProdigyCustoms
01-31-2010, 04:33 PM
The truck accesories will not fit, the alternator will stick through the hood. You will have to use Corvette or Camaro accesories. Or a aftermarket kit
dropped72ss
01-31-2010, 06:42 PM
Does that mean I'd have to buy a whole new kit ($1000)? Or can I just buy some new brackets? What's the best way to make it work?
ProdigyCustoms
01-31-2010, 07:06 PM
The brackets for sure, the accesories MAY work, there is a dozen different clockings for the lugs on the alternator.
dhutton
02-01-2010, 04:51 AM
Did you look at the brackets from kwik performance?
http://www.kwikperf.com/
alocker
02-03-2010, 05:11 PM
Not to sure why some say it won't work. Here is my truck accessory setup in a 72. The only thing you need is an S-10 PS pump pulley to clear the steering box. I have about an 1/2 inch clearance to the inner hood supports. I use factory 350 SBC mounts with Edelbrock adapters.
2ndgenhunter
02-03-2010, 07:49 PM
Alocker,
What headers are you running?
alocker
02-03-2010, 07:57 PM
Edelbrock's. They have the same issue many complain about, the #2 primary is about a 1/2 a mm from the x-member and sometimes it rubs.
Samckitt
02-04-2011, 02:26 PM
Hey alocker, you got pics of the truck accessories in your ride you can share? I'm planning an L92 in an 80's G body. Chassis are similar, was hoping all would fit.
thanks
garys 68
02-05-2011, 03:25 AM
I'm doing a 72 442. I've seen several other A bodies with the truck accessories and even the intake. I'll be test fitting this weekend.
Here's my setup with a smaller PS pulley.
https://static1.pt-content.com/images/pt/2011/02/DSCN0232-1.jpg
If it doesnt fit, I'll just cut off the top of the bracket and mount it like I did on my 68 corvette.
https://static1.pt-content.com/images/pt/2011/02/accdrive-1.jpg
