View Full Version : Chevelle wheel info needed
DAVE68
01-30-2010, 06:18 PM
Need some help deciding proper wheel size/backspacing. 68 chevelle with ls1 front brakes, so the 15's gotta go, still drums in rear for now. Lowered with eibach pro kit 1.3 drop springs, i already rolled the rear wheel lips. No tailpipes. Decided on AR ttII's 17 by 8 front and 18 by 10 or 18 by 9.5 rear. Is the 10 possible on the rear without any modifications, if it is what backspacing? I want the staggered look. With the 18 how tall of a tire can i run without issues? potholes! I've read on here that 68-72 chevelles can handle a large wheel on the rear. Thanks in advance, Dave
street3285
01-30-2010, 07:58 PM
You should be fine with a 10" wide wheel in the back without modification, if you run the right tire. Talk to DriverzInc, they will set you up with a perfect fit with great pricing.
JustinB
01-30-2010, 08:16 PM
Dave, we have set up a lot of the 68-72 A body guys with 18x10's with up to a 305 rear tire. Feel free to give us a call on Monday and we can help price you a AR wheel/tire package.
DAVE68
01-30-2010, 08:44 PM
Thanks, ill give you a call. I went to your site after street3285 recommended me to, but i did'nt see any prices, thanks.
Roadbuster
01-30-2010, 09:54 PM
68 chevelles are a little different from the 69 to 72 chevelles in the rear wheel wells. There is a step in the inner fender that moves in an inch or so behind the wheel lip. Put your fingers under the rear wheel lip and you should feel it. Be sure to check that your new wheels and tires will clear it!
Jon
DAVE68
01-30-2010, 10:17 PM
Thanks Jon, i'll check in the morning. I got the same lower a-arms.
