View Full Version : Finn's Auto Restoration 69 Concept Camaro
C5DENNY69
01-28-2010, 01:06 PM
Wanted to share some pic's of our 69 Concept Camaro.
Finns Auto Restoration & Custom. www.finnsautorestoration.com (http://www.finnsautorestoration.com)
We are located in Molalla Oregon and have been in business since 1992. Molalla is within an hour of Portland Oregon. We are one of the larger Restoration shops in the State of Oregon. We usually have 15-25 Restorations going on at a time.
Our project is based off of a 69 Camaro that we have redesigned to be more modern inside & out. The drive train is newer Corvette (C5-C6) front & rear suspension, LS7 engine, and 6 speed transaxle.
The Chassis is an Art Morrison Max-G modified by Schroder Speed & Custom to accept the Corvette transaxle & narrow the Corvette rear suspension mounting points.
The engine is a GMPP LS7 with a Magnuson TVS2300 supercharger. The engine is being upgraded by Mast Motorsports with their Blower cam & M90 ECM & engine harness. The engine should make over 775hp. Front drive assembly is a Vintage Air front runner.
More info and sponsor list to come. Enjoy, Denny Finn
104 W. Main St.
Molalla Oregon, 97038
(503)829-8488
Motown 454
01-28-2010, 01:45 PM
Nice looking set up. It should be a sweet ride when your done. Keep the updates coming.
CruizinKev
01-28-2010, 02:09 PM
wow looks awesome!!!
Smock67
01-28-2010, 11:30 PM
looking real good that is one sexy chasis. can't wait to see more pics
C5DENNY69
01-29-2010, 11:21 AM
Thank you. I post more pics & info in the future.
Denny
cdoggy81
01-29-2010, 02:47 PM
Cool ride!
BTW, what size rear tires are those, 335? They look HUGE :)
C5DENNY69
01-29-2010, 03:51 PM
Cool ride!
Thank you!
They are Mickey Thomson SR street radial. 29-18 R20
They measure 17.25" from side wall to side wall. (unmounted)
They are 430MM? something like that?
Thanks, Denny
C5DENNY69
02-01-2010, 06:52 PM
The Chassis is an Art Morrison Max-G modified by Schroder Speed & Custom to accept the Corvette transaxle & narrow the Corvette rear suspension mounting points. Brembo 15" 6 piston frt & 13.5" 4 piston rear.
More info & sponsor list to come. Enjoy, Denny Finn
104 W. Main St.
(503)829-8488
www.finnsautorestoration.com (http://www.finnsautorestoration.com)Sponsors include:
SPONSOR LIST:
American Auto Wire; hwy 22 kit.
Brembo Brakes; 15" drilled front 6 piston, 13.5 " drilled rear 4 piston mono block.
B&M; ripper shifter
Canton Racing Products; dry sump oil tank.
Cherry Bomb: mufflers, tubing.
The Drive Shaft Shop; custom drive shaft & half shaft (rated 1000hp).
Eddie Motorsports; Billet Hood hinges, tail lights, SS hood louvers, & more.
GMPP Dr Jamie Meier: LS7 crate engine
Goodridge: fluid transfer systems.
Hush Matt; sound deadening & heat resistant materials.
Ididit: aluminum steering column, steering shaft & joints.
Quick Time; C5/ C6 bell housing/ scatter shield.
Racepack: gauge pack.
Recaro; heated & cooled seats.
Ricks Stainless Tanks; custom fuel tank & pump.
Macs Radiator (Portland Oregon); Custom Radiator, heat exchanger for super charger, and aluminum radiator support.
Magnuson Superchargers; TVS 2300 supercharger kit.
Mast Motorsports: Upgrade & dyno tune engine with their M90 ECM, engine harness & blower cam. Thanks guys!
McCleod; RST twin disc clutch (rated 800HP)
Mickey Thomson; SR street radial 29x 18 x 20. 17.25" side wall to side wall (aprox 438mm unmounted)
Percys; laminate side windows.
Schroder Speed & Custom; modify Art Morrison Max G chassis to accept Corvette transaxle & narrow suspension mounting points. Thank you!
Schutt; hand made steering wheel, shift knob, pedal pads.
Super Chev Parts (Portland Oregon); sheet metal, parts, etc.
Vintage Air; Gen 4 heat & A/c system, front runner accessory drive.
Wilwood brakes; remote reservoir master cylinders & pedal assembly
More info to come. Denny
