View Full Version : Razor Camaro Hood
Ringbrothers
01-20-2010, 02:38 PM
Hey guys! It's been a long time since I've been able to get on the forums.
Hope everyone is doing well!
We made the hood from Razor a direct repalcement for guys that were interested.
Specs:
Made with woven fiberglass for strength
Vacuum bagged with a high temp epoxy resin unlike most fiberglass hoods on the market
Nomex honeycomb core for strength
Aluminum hard points so you can drill and tap for hinges and latch
Sprayed with an in mold catalyzed primer for easier finishing body work
The quality of this hood is second to none.
True and straight hood
Installation easy as sand, prime, sand and paint!
Hood weighs 34 lbs
If anyone has any questions please let me know.
Thank you!
Staci
tmadden
01-20-2010, 03:20 PM
How much?
colt zantop
01-20-2010, 03:45 PM
67-69 or just 69's??
Bryce
01-20-2010, 03:49 PM
kinda heavy My fiberglass weighs in under half of that and has zero deflection. My steel hood weighed 42lbs.
Ringbrothers
01-20-2010, 06:02 PM
I believe when Jim and I talked about it he said it would fit the 67-69. I will confirm that tomorrow.
$1150 plus about $120 in freight.
Ringbrothers
01-20-2010, 06:14 PM
We are not here to compare sizes - especially when you consider the size of Mike's feet. I mean come on he can wear my shoes.
GrnDragon
01-22-2010, 12:40 PM
It's hard to tell from the pictures and all of the pictures I can find of the Razor actually never show good shots of the hood, what are the differences in the cowl?
Does it start closer to the front edge of the hood?
Does it slope longer than original cowl hoods?
Does the extra long overhang limit the hood from opening all the way?
Also, any possibility of a Group Purchase to help the cost a little, or could it be packaged with your hinges and hood stops?
Ringbrothers
01-24-2010, 10:08 AM
There aren't a lot of shots of the hood. Below is a shot I had that might help?
I will get back to you on your questions on Monday. I have to get some technical help!
I will see what I can do about a bundle price too.
CruizinKev
01-24-2010, 10:11 AM
wow looks awesome :drool:
thetoystore
01-24-2010, 10:33 PM
love the hood and congrats on your success at barret jackson
Ringbrothers
01-25-2010, 08:13 AM
Thank you!
senor_camaro
05-11-2010, 12:17 AM
dang that looks awesome, how much would a set up like that run?
Ringbrothers
05-14-2010, 11:42 AM
$1200 for fiberglass - I have one hood in stock if anyone is interested.
Staci
Procharmo
06-04-2010, 11:29 PM
You guys should experiment with the opening to see how it lines up with popular side mounted Procharger models ( P1SC, D1SC, F1, F1A, F1C, F1R). It could be a good solution to cold air induction on an rear facing Procharger/Vortec blower......
tellyv
06-05-2010, 04:36 PM
here's a pic of one installed the fit is excellent and it's straight unlike most other aftermarket hoods!
