View Full Version : 69 Camaro hardware/fasteners
Joker69Camaro
01-20-2010, 12:00 PM
I am in the middle of rebuilding the front end on my camaro. I was wondering if there was an option out there for any plated hardware that would reduce rusting for the lower controll arms? If not I was going to just media blast the factory hardware and re-use.
I did a search and found nothing on this here or on google. Any help is appreciated.
Jeff
rivs68
01-20-2010, 12:18 PM
"Totally Stainless" Could supply you with S.S. fasteners....Definately won't rust...
Joker69Camaro
01-20-2010, 12:44 PM
But will stainless have the tensil strength? I don't even know what grade those fasteners are.
*EDIT* Nevermind they have grade 8 stainless.
CarlC
01-20-2010, 02:54 PM
Do a search, there's info on stainless and other fasteners.
Just say no to stainless in structural/life critical applications.
676869addict
01-20-2010, 02:58 PM
totally stainless sells a kit that is grade 9 look em up
JRouche
01-20-2010, 09:48 PM
I think you would be ok with blasting the original bolts if they are in good shape. If they have some corrosion on them then no. But just to clean them up yes. Stainless? Well yup, you can get a small variety of stainless fasteners that are very strong. But they are usually small fasteners for specific purposes and expensive. Id stay away from them for suspension purposes. JR
JayBird
01-27-2010, 10:49 AM
Got my stainless bolt kit from Frank at Prodigy Customs. All are button allen head bolts.
MuscleRodz
01-27-2010, 12:54 PM
Totally Stainless makes a high strength chassis bolt kit made up using ARP bolts. They are very expensive.
ProdigyCustoms
01-27-2010, 01:25 PM
We use grade 8 for the subframe bolts
MuscleRodz
01-27-2010, 06:59 PM
We use grade 8 for the subframe boltssame here
Joker69Camaro
01-28-2010, 05:54 AM
Thanks guys, I just media blasted and re used the originals. All of them were in great shape!
dipren443
01-28-2010, 06:14 AM
same here
Yellow zinc dichromate GR 8 fasteners for all structural applications. Not even discussing tensile strength issues, stainless loves to gall with contact to dissimilar metals.
ProdigyCustoms
01-28-2010, 07:04 AM
MUST use antiseize on stainless.
dipren443
01-28-2010, 07:08 AM
Frank,
Agreed, but what are your thoughts on using Anti-seize in structural apps?
ProdigyCustoms
01-28-2010, 09:13 AM
I only use it on stainless and I do not use stainless on structural apps
dipren443
01-28-2010, 11:22 AM
:cheers:
Kinda what I figured.
