View Full Version : Wayne Due C4 Frame Users, I Need HELP!
ATAK, Inc.
01-18-2010, 08:11 AM
After way longer than I even want to think about, assembly of my car, Time Warped, has begun. And just as quickly, ground to a halt. Wayne designed the LCA's to mount to the frame with 1/2" bolts. But C4 Corvette LCA bushings used 12mm bolts.
What is the best route to take? 12mm bolts would have just a bit of slop in them that doesn't sound like a good plan to me.
I guess the only other option is to ream out the bushing pins, or is there something I'm missing???
Please Help, I really want to keep moving forward, and after a month of cleaning and painting the firewall and underneath I was so happy to actually join parts together.
Tom
MonzaRacer
01-19-2010, 04:07 AM
go check out Steves Bad Penny thread, he simply made sleeve spacers to take up "slop" any good shop should be able to cut some down on a lathe, just make sure they are a few thousandths shorter than holes and fit snug(say lightly tap in with hammer) in frame and remember to use good bolts. Steve used 12mm with 10.9 hardness.
ATAK, Inc.
01-20-2010, 08:57 AM
Thanks MonzaRacer, I ended up getting a crippled drill press I have up and running and drilled out the holes on the bushing pins. Just for the want of another 0.014":)
