View Full Version : '67 Vette Engine Transplant...
4sfed
01-17-2010, 05:43 PM
I've just recently completed my engine transplant. We wanted something that ran like new, and had decent reliable power. We also wanted to be able to pop the hood at shows and most people walk by and compliment on the nice "original" motor..... but, the people that REALLY know their stuff to take a double-take and scratch their heads trying to figure out what it is. :hmm::smoke: So... here is what we came up with...
I'm reposting my diary from another forum. So, bear with me, and I'll get all the content up in a few minutes. Look for the "[END ORIGINAL POSTS]" comment. ;)
Stand by...
4sfed
01-17-2010, 05:44 PM
I thought I'd get some ideas on the "concept" for the new engine. :) I really want to keep it looking vintage, but that actually requires quite a few trick parts to pull that off. The ZZ4, like all the other sbc crate engines, looks pretty plain. Here's a picture:
https://static1.pt-content.com/images/pt/2010/01/80924502609-1.jpg
Normally, I like the black. :o :D But, for this application, I'm thinking the original "Engine Orange" paint would be best suited. So, when the engine arrives on Thursday, we are going to wipe it down with enamel reducer and re-spray it with Plexi-Kote in the correct orange. I've asked around, and it seems like it won't hurt anything if we paint the (aluminum) heads... :dontknow: We'll keep the intake manifold unpainted, and we need to buy a new water pump anyway (Corvette requires a "short" neck water pump) so we'll keep that unpainted too.
Next thing that was bothering me was using the factory exhaust manifolds on the new motor. They are not a perfect match, but they do fit, and it would allow me to use the rest of the exhaust that's already there. I didn't think there was any other option besides headers... which I don't want to do. I was poking around and found these Ram's Horn smooth manifolds from Speedway Performance! :rock: They have the correct (d-shaped) design, and the same look as the originals. But, they are supposed to flow WAY better... and they look awesome too, all smoothed out.
https://static1.pt-content.com/images/pt/2010/01/9300300_L-1.jpg
Next was the valve covers... :banghead: The crap, stamped vc's that come on the ZZ4 look like ass. :o They are center bolt, due to the Vortec Heads, so I couldn't modify my finned "Corvette" covers to work. I couldn't find any other designs that I liked.... BUT, when I found the article on the Ram's Horns, they also put on a set of SWEET PML Valve Covers! My jaw dropped when I saw these!
https://static1.pt-content.com/images/pt/2010/01/11041_pol_lg_2-1.jpg
They will even mill holes in the correct place for pcv valves or breathers, if you like. They also cast the windage baffles right in the piece. :congrats:
https://static1.pt-content.com/images/pt/2010/01/11040_inside-1.jpg
So... :o I have a Barry Grant Demon carb coming as well. It's their "crate engine" model, and was designed specifically for the ZZ4 GMPP engine. So, that should go well, and it looks purdy too. An added bonus is the Holley style design (float bowls sit in line with the block) which is more "nostalgia" cool than the EdelCRAP Weber carb I had on there before. :D
https://static1.pt-content.com/images/pt/2010/01/1321282010CZZ4-1.jpg
https://static1.pt-content.com/images/pt/2010/01/1321282010CZZ4_3-1.jpg
https://static1.pt-content.com/images/pt/2010/01/1321282010CZZ4_2-1.jpg
Now, I just need to find a nice polished aluminum air filter housing... But, I'm sure that it's out there, somewhere....
4sfed
01-17-2010, 05:45 PM
Engine is out! :rock: New motor is here! :D :rock:
https://static1.pt-content.com/images/pt/2010/01/DSCF1322-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1329-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1328-1.jpg
Throw-out bearing was ready for just that... it got THROWN OUT! :o ;)
https://static1.pt-content.com/images/pt/2010/01/DSCF1327-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1326-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1343-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1332-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1333-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1334-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1337-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1347-1.jpg
Tired old girl... :( :o
We'll be masking off the new engine for paint tomorrow... all the rest of the new shiny-goodness should be here by Monday. :rock: Until then, we'll also be detailing and touch-up-painting the engine bay.
4sfed
01-17-2010, 05:47 PM
All masked off and ready to paint! :rock: :burnout:
https://static1.pt-content.com/images/pt/2010/01/DSCF1349-1.jpg
Well.... it's ORANGE! :rock: *cough* shoulda used a mask *cough* :o
Had to wait for the "fog" to clear from my little quarantine area. :o
https://static1.pt-content.com/images/pt/2010/01/DSCF1353-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1354-1.jpg
It's humid out... so it's still a little tacky to take off the tape. :D
https://static1.pt-content.com/images/pt/2010/01/DSCF1356-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1357-1.jpg
Here it is with the masking off...
https://static1.pt-content.com/images/pt/2010/01/DSCF1360-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1358-1.jpg
Parts have been sandblasted! (Thanks, Brian... and Cessna/Citation... lol :o ;) )
https://static1.pt-content.com/images/pt/2010/01/DSCF1362-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1363-1.jpg
Also, installed the new Muncie Side-Cover from AGE...
https://static1.pt-content.com/images/pt/2010/01/DSCF1365-1.jpg
This "trick" side-cover has new, beefier, linkage arms and a whole new design that incorporates ball bearings and new seals to keep from leaking. :rock: I also installed their reverse linkage seal and tail housing seal. :) (In the next pic is the OLD, TIRED, side cover... :o )
https://static1.pt-content.com/images/pt/2010/01/DSCF1364-1.jpg
I bought these from Terry at TBTrans (dot) Com. He was a great help, as the side cover is a PITA to put back together! :argh: :o
4sfed
BEFORE:
..... And AFTER:
:cool:
https://static1.pt-content.com/images/pt/2010/01/DSCF1373-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1374-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1376-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1377-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1378-1.jpg
Here's a pretty trick lookin' dual-feed fuel line for the Demon Carb... it's clear anodized billet w/ black AN-fittings. :) I was surprised how good it looked, and how well it was made (it's a Jeg's Brand part). I wonder who makes them for Jeg's, because they did a nice job. :dontknow: :o
https://static1.pt-content.com/images/pt/2010/01/DSCF1380-1.jpg
4sfed
01-17-2010, 05:48 PM
It's in and it RUNS!!!! :cool::thumbs::cheers:
https://static1.pt-content.com/images/pt/2010/01/DSCF1391-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1423-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1430-1.jpg
http://s105.photobucket.com/albums/m227/oblivion187/Vette%20Rebuild/?action=view&current=VID00008.flv
:D :D :D :D
(Keep in mind, it's still set on "pig rich"... so it's smoking a little bit. :o )
4sfed
01-17-2010, 05:49 PM
I forgot to update...
After about 1 hour of drive-time, the Blaster 2 coil blew the points in the distributor. Did it again after a fresh set of hi-po points. :ack: So, I broke down and got a MSD Pro-billet dist and 6AL brick. .... Runs way better now. (And, I can still use the dist shield). I hid the 6AL behind the coolant reservoir tank. ;)
The stock(ish) single throttle return spring was too weak. It would stick the throttle open ever so often... So, I also installed a double spring.
When we put the exhaust back on (driver's side), we found the pipe junction at the sub-frame (middle of the car) was all jacked up. When the exhaust was put on by the previous owner, they didn't fit the pipe good enough in the junction and installed the clamp too far back. That put a crease in the rear pipe, which doesn't allow the new mid pipe to fully seat. Now, I can't get it to seal. :toetap: So, it looks like she's off to the exhaust shop on Monday. :smash:
4sfed
Here's some updates! I ordered and installed the "N11 Off-Road" exhaust from CC.... It sounds GREAT! :thumbs:I will have a few vids this coming week for everyone that is interested. Corvette Central was STUPID to shoot a vid of their new exhaust using some goofy-assed RADICAL BIG BLOCK (523ci, or somthing) engined Vette to show the sound of this setup... :crazy::smash: So, I will have a nice sounding vid for all those that are still looking at this piece. ..... For now, I'm just satisfied that I can finally run the project down the road and work out the "bugs". Here are a few pictures to hold you all over until the vid.... (I forgot how much SHINE the old girl had, after being under the knife for so long! So, here's a few of my fat ass in the reflection (camera was not able to focus real well under the lights... but, trust me, you could SHAVE in it...).
https://static1.pt-content.com/images/pt/2010/01/DSCF1505-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1509-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1513-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1516-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1518-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1519-1.jpg
https://static1.pt-content.com/images/pt/2010/01/DSCF1520-1.jpg
[END ORIGINAL POSTS!!!]
NOGO
01-17-2010, 05:53 PM
Looks great! Nice job!
4sfed
01-17-2010, 05:55 PM
Sorry, I was posting a bunch... Scroll up! :poke::naughty:
ls6monte
01-17-2010, 06:04 PM
Very nice!
4sfed
01-17-2010, 06:09 PM
Thanks, Guys!
Rag-Rat
01-17-2010, 07:28 PM
I like the retro look of the engine. It looks like it came with the car.
joco
01-18-2010, 01:11 AM
Looks great! Nice job:cool:
Greets, Jo
Paul_J
01-18-2010, 05:01 AM
I love that vintage look. Great Job.
bonecrrusher
01-18-2010, 05:58 AM
Wheres the air cleaner from?
srh3trinity
01-18-2010, 06:16 AM
As much as I like LSX motors stuffed between frame rails. There is something to be said about a nice small block. Great execution. The engine looks clean and like it belongs in the car, everything is well hidden and the dirt track style air cleaner looks great. Beautiful car!
4sfed
01-18-2010, 09:06 AM
The air cleaner is from ProForm. Part number 141-691. I had to modify it a little to fit the Demon Carb's mechanical secondary linkage... but, I think it it's a nice, period looking, piece. It's got a super deep base plate, so I was able to clear the stock hood with a 3" K&N filter. Plus, it's made of spun aluminum for a cool finish (I HATE CHROME! lol)
4sfed
01-18-2010, 09:16 AM
Thanks! And, I agree.... We were looking at some LSx motors and other options. They are real nice for drivablity... but, I must have a little bit of "purist" left in me. haha I may get internet-slapped, but I kinda thought if we put a bunch of computers and fuel injection and other things in there... the car would loose it's soul. Plus, I like tinkering with carburetors. lol
4sfed
01-18-2010, 09:17 AM
Thanks, Cris, Paul, and Jo!
Jon69RagTop
01-18-2010, 10:55 AM
Good idea on keeping the original theme. Very well executed.
4sfed
01-18-2010, 11:28 AM
Thanks, Jon! :smoke:
CruizinKev
01-19-2010, 08:00 AM
looks awesome! great job :twothumbs
jackfrost
01-19-2010, 11:45 AM
great car... nice upgrades! :razz:
(go buckeyes!)
WS6
01-19-2010, 03:13 PM
I've done two different 65 roadsters using ZZ4 engines. Both wanted drivers and didn't want to use their original 327s. The ZZ4 is a great engine.
One thing I did notice though, the ZZ4 uses L98 cylinder heads not Vortec heads. If you ever plan any changes you'll need to keep that in mind. The engine is essentially a late L98 minus the tuned port intake.
Looks great. I love those valve covers. I'll have to remember they are out there.
4sfed
01-20-2010, 11:32 AM
Thanks, Trey... and, of course, you are correct on the heads. I miss-spoke. :)
Thanks to you too, Dave and Kev.
4sfed
01-26-2010, 04:44 PM
New exhaust video!!! :smoke:
This is the sound of Corvette Central's "N11 Reproduction" exhaust....
http://www.youtube.com/watch?v=a5Zx9225ejM
(I'm chasing down a starter solenoid issue, and I've still got the carb running rich (smoking) :Alchy:)
Wadda ya think?
monteboy84
01-26-2010, 05:03 PM
I LOVE your car, very nicely done sir.
NOT A TA
01-26-2010, 05:20 PM
Nice car! I like the way you kept the period look underhood.
4sfed
01-26-2010, 05:43 PM
Thanks, Matt and John! :cheers:
