View Full Version : Is there anyone who makes something similar to this?
rossmacd
01-16-2010, 10:41 PM
but at a lower price? $300 from Summit seems awful high to me! Someone has to have seen the market for something like this.
http://www.dedenbear.com/mrc1txt.htm
FULMNTE
01-17-2010, 07:11 AM
Maybe Dakota Digital?
rossmacd
01-17-2010, 05:02 PM
Not that I have seen. You would think with the number of relays that we run (I have 5 IIRC) that a product like this would be commonplace; everything in one location, easily wired, and most of all, much more professional looking than a bank of relays screwed together with another bank of fuses nearby.
zerotofear
01-17-2010, 06:17 PM
Spaghetti Menders.com
TnBlkC230WZ
01-17-2010, 06:35 PM
If you can do the wiring yourself, Delphi sells a module with 4 relays and 6 fuses that is about the size of a credit card. You could probably assemble it for under $50. If you need more circuits, they have boxes that will hold three and four modules.
rossmacd
01-18-2010, 06:35 PM
Any idea where I can find that Delphi part? They make about a billion things.
rossmacd
01-18-2010, 06:37 PM
That spaghetti menders piece may be similar, but at $269, I'd rather get the Dedenbear piece.
all wired
01-20-2010, 10:11 AM
it sounds like this may be what youre looking for..
http://www.yellowbullet.com/forum/showthread.php?t=146727
67 455 Bird ragtop
01-20-2010, 11:16 AM
That is a sweet board. I just emailed Dave about getting one made for my 67 ' Bird. That will solve a lot of wireing issues down the road.
rossmacd
01-22-2010, 08:01 PM
That's a good, cheap solution... onto the parts list it goes.
TnBlkC230WZ
01-23-2010, 08:37 AM
Here is the linke to the catalog. Look in the electrical center section. www.mouser.com (http://www.mouser.com) sells most of the components. Using this catalog, I built the entire electrical system for my car. Fuse panel and all.
http://connectors.delphi.com/DCSGDMCS/DCS/Catalog/CatalogIndexSearch.aspx?vUser=GuestUser&vID=Automotive
I must admit, the circuit board looks pretty nice. Mouser will have a NEMA 4X box to mount it in so you can put anywhere you want. It is the box with the clear lid
https://static1.pt-content.com/images/pt/2010/01/IMG_0231-1.jpg
jtm311
01-23-2010, 10:28 AM
As shown in TnBlkC230WZ car I just picked up yesterday a engine fuse box from a late model TA it came with two fuse packs both have like 6 relays in them. It will be much easier to hook all the new updates like headlights, alarm, well you get the idea. Cost me $25.00
John
TnBlkC230WZ (https://www.pro-touring.com/forum/member.php?u=7756) https://www.pro-touring.com/forum/images/statusicon/user_offline.gif
John McIntire
01-23-2010, 12:50 PM
Wow! That Nitrous Dave set up is killer!! Definitely will be added to my parts list!
67 455 Bird ragtop
01-30-2010, 08:12 PM
John
Was it easy to find a schematic for your fuse block??
jtm311
01-31-2010, 08:41 AM
Sorry never looked for one, when I took if from the car I asked the guys to leave about 6" of wire attached, then as I need a circuit I just replace the wire under the fuse box. I will try post a photo later today.
John
TnBlkC230WZ
01-31-2010, 10:20 AM
I built my own schematic. All the parts are readily available. www.mouser.com (http://www.mouser.com) sells them individually. If you PM me your email address, I'll send you the Visio. You can get the Visio viewer from Microsofts web site. There will be many similarities, but you will want to taylor to your accessories. All parts in my pic are USA or Canadian made.
67 455 Bird ragtop
02-01-2010, 07:05 AM
PM sent. Thanks.
jtm311
02-01-2010, 07:48 AM
Here is the one I'm using. Nice and small :) You see they have 5 relays and a good amount of fuses.
John
67 455 Bird ragtop
02-01-2010, 08:35 AM
Thanks for the pic. Will definately help me decide which way to go with my buiild for extra circuits.
rossmacd
02-01-2010, 08:15 PM
John
What car is that from? It looks pretty ideal.
jtm311
02-02-2010, 04:50 AM
This is from a 4th gen Firebird or Trans am.. The nice thing is this car comes with two of the same thing. So you could run one on each side.
John
67 455 Bird ragtop
02-06-2010, 04:51 AM
Thanks for the tips on this. I picked up a fues/relay box and the mounting bracket from a 1993 Camaro yesterday at a local yard. $15 bucks. Now all i need to do is find a wiring schematic for it.
slownova73
05-29-2010, 11:17 PM
http://shbox.com/1/schematics_wiring.html
everthing you need to know about f-body wiring lol
