darren@ridetech
01-15-2010, 06:32 AM
All right guys, lets here hear it..... Questions, concerns, comments?
http://www.ridetech.com/more/2009/11/15/new-select-series-shocks/
RideTech is pleased to bring the latest in OEM shock technology to the hotrod market with the new RideTech SELECT series of shock dampers. The RideTech Select series is a steel body monotube damper with TWO sets of independent internal valving so you can choose between a soft compliant ride or a firmer “sport mode” for handling performance…all at the touch of a switch!
The RideTech Select series will be available in a coilover, a ShockWave [airspring], or a stand alone configuration with no surrounding spring. RideTech [formerly known as Air Ride Technologies] has long been known for the ShockWave, a combination airspring and shock absorber. With the new Select Series damper, RideTech is now the ONLY manufacturer able to bring this new electronically selectable valve technology to the coilover customer as well. The Select Series is also available with no coil or airpsring.
The heart of the RideTech Select is two independent sets of electronically controlled valving inside the monotube damper. In default mode [no power applied], the lower valving stack is engaged and provides a very compliant ride to optimize a plush ride quality. When power is applied through a dash mounted control panel, the upper valve stack is engaged to firm up the ride quality and provide extra cornering andhandling performance, or to optimize ride quality when towing or carrying a heavy load such as passengers, luggage or a trailer.
This selectable valve technology has been refined and proven on many OEM vehicles over the past 9 years. RideTech now offers the ultimate solution to the ride quality and handling issues of the hotrod and trailering market… the RideTech SELECT!
