View Full Version : Camaro better step up its game.
Droolguy
01-14-2010, 06:34 AM
http://videos.streetfire.net/video/2011-Mustang-50L-V8-Dyno_727282.htm
Considering the Camaro and Mustang are neck and neck around a track right now, and the Mustang only has ~315hp.
Looks like were off to the races! Hopefully Camaro counters w/ 500+hp, since it has a 400lb weight disadvantage.
Where is Dodge in all of this???
Also, I wonder what they are going to do w/ the 500 now since the GT is encroaching on its turf.
justasquid
01-14-2010, 09:12 AM
At the all you can eat buffet.
hifi875
01-14-2010, 09:28 AM
556hp lsa powered z28
Droolguy
01-14-2010, 10:28 AM
No joke, the Challenger needs to go on a massive diet.
As for the Z/28... I didn't know that had been confirmed yet.
Either way looks like the horsepower race is back in full swing (minus Mopar anyway), good thing too since I was born in 87' I didn't get to partake in the first one.
6'9"Witha69
01-14-2010, 11:03 AM
Z/28 is pretty much a sure thing. Considering the expected power, Everyone better step it up.
Damn True
01-14-2010, 11:11 AM
dyno schmyno, I want to see more refinement and development in the suspension.
moreHP
01-14-2010, 11:58 AM
Nothing wrong with the two sides getting into a modern muscle car war! Its good for us gearheads since the parts will eventually trickle down to our projects.
Droolguy
01-14-2010, 12:12 PM
All either of them need is different springs/shocks and some R compounds to be well out of the driving capabilities of 99.9% of people.
Although I wouldn't mind a factory option with those included... a true track pack. Throw in some <20lb 18 forged wheels and it would be the best option *ever*.
jknight16
01-14-2010, 12:18 PM
the new Camaro will need some seriously beefed up suspension mounting points and components if you're going to run sticky tires. There's a lot of squish in the factory suspension. That said, it's still badass and I wouldn't mind making those improvements one bit.
It's too bad the giant wheel wells make an 18" wheel look so goofy. There's just no easy way around that.
Damn True
01-14-2010, 12:51 PM
I know. I wish they hadn't designed that thing around 20" wheels. I don't think they look good on anything.
CarlC
01-14-2010, 02:11 PM
Much of the squish comes from massive rubber body mounts. There are many companies that can deal with that. However, some of the NVH qualities go away so there is always a tradeoff.
tones2SS
01-14-2010, 03:00 PM
I don't think Dodge is going to be out there trying to be building a "super" sports car. I think that Dodge is still "under water", is it not??
Droolguy
01-14-2010, 04:08 PM
If Dodge is underwater then GM is stuck on the bottom of the ocean with a leaking submarine, which happens to be why the Z/28 hasn't been confirmed yet. They can't afford it right now so it keeps getting pushed back.
trapin
01-14-2010, 08:08 PM
18's will look good if you drop the ride height a bit.
And how do you do that?
You call Detroit Speed & Engineering....that's how you do that.
http://www.detroitspeed.com/projectpages/2010-camaro/2010-camaro-main.htm
