68400BIRD
01-12-2010, 10:26 AM
I need some advice.
I have a 1968 Firebird with a 400 motor. I'm not looking to have more than 500hp. This will be a streed driven car with no strip time at all. Just a fun cruiser that can hit the turns and handle pretty good.
The car came with a 2nd gen rearend in it and it was all cobbled together. I sold it as soon as I found out it did not fit right.
Over the next couple of months I bought a 12 bolt rearend with the correct width but it needs wheel bearings and seals at a minimum. It is a 3:08 open rearend.
I then thought that I hit the jackpot with a craigslist find. It was suppose to be a 10 bolt with 3:73 posi. It ended up being a 1972 or 73 8.5 10 bolt with 2:73 open rear. He ended up giving it to me.
I just found a (JY G264 1W) which looks to be a 1973 8.5 posi with 3:42 gears. Price is around $400-$500.
Money is real tight and I cannot afford to make the 12 bolt the way I want it right now. I can fix the bearings and seals and add a posi and new gears down the road. Install new perches and bolt it in.
or
I can sell both rear ends and put the money towards the recently found 10 bolt. The 12 bolt would have the cool factor but it is probably not needed for my motor combo. I would also like to put a overdrive tranny in down the road. I'm not sure if the gears would be a good combo with a over drive. Any ideas or comments are welcome.Thanks
or
