View Full Version : Detnation, Pinning? 383 storker help?
jigga99
04-17-2005, 07:16 PM
i just put in a crate 383 and it wont stop pinning? has 0 timing 2 '' exhaust no headers yet next week will they stop the problem? i run 93 octain ???
OHCbird
04-17-2005, 07:48 PM
You really have to post a few more details in order to get somewhere- and what do you mean by "0" timing?
Is it dual 2" exhaust, or 2" primaries?
zbugger
Ummmm..... What's the timing at? Set it to at least 10-12 initial. That should make a difference right away.
jigga99
04-17-2005, 08:30 PM
its dual exhaust, the shop guy set it to 0 said he didnt want to take any more out?
zbugger
04-17-2005, 09:06 PM
What? Hmmm.... That sounds odd. How's the idle? Set the timing up and see how it reacts. Or, really, see what it's at now. Then you can go from there. It really sounds like the timing is off though.
jigga99
04-17-2005, 10:01 PM
he said he had it at 4 and it was bad? im not to good with tuneing need all the help i can get.
Smoke'm
04-18-2005, 08:00 AM
did you or the engine builder pay attention to Quench??? sounds like it may be to tight.
jigga99
04-18-2005, 09:05 AM
quench???? just talk to the mechanic said he had it at 4 deg detnated so he took it back to 0 deg, said he probly needs to take more out? the idle is ruff but thats probly the cam.
zbugger
04-18-2005, 03:55 PM
You say it's a crate 383. What company did you get it from? What cam is it? Can you give all the engine specs? Also, are you timing it before TDC? I hate to say it, but there's some real morons out there when it comes to engines, and I have no idea how they keep their jobs. Please give us all the engine specs and we'll get you a good answer.
jigga99
04-18-2005, 08:43 PM
its a class 3
http://www.jasperengines.com/performance/classi18.pdf
Lowend
04-18-2005, 09:16 PM
I am not really suprised that you are having pinging problems. Iron heads, a fairly small cam and 10+ compression ratio.
I would baseline the engine with 8 deg BTDC with 30 deg Total timing all in by 2700RPM
When in doubt the carb should be running rich ~12-1 A/F ratio
The headers can help supress some pinging as they will get some of the heat out of the combstion chambers.
