View Full Version : 62 Nova 4door Chevy II Pro-Touring "light"
Martin71RS
01-08-2010, 12:26 PM
I needed something to work on now the Camaro is "sort of" finished so I started a budget build.
Bought a project car a year ago and did some work but the Camaro demanded more time last year then I thought.....
https://static1.pt-content.com/images/pt/2010/01/marktplaats02-1.jpg
I am not planning a full out pro-touring build like with the Camaro, but I will improve suspension, brakes etc. so I'll just see where it leads me.
anyways, have a look on
www.pro-touring.nl (http://www.pro-touring.nl)
Nova, page 1, 2 and 3
Martin
CruizinKev
01-08-2010, 01:22 PM
cool project! :twothumbs
Martin71RS
10-02-2010, 06:52 AM
Finally some progress again
click on the Nova
Page 5
Martin
Martin71RS
10-24-2010, 04:40 AM
some more work done,
www.pro-touring.nl
click on the Nova
Page 6
Martin
Martin71RS
02-06-2011, 07:04 AM
Home made disc brake conversion:
www.pro-touring.nl
click on the Nova
Page 7
I got the brackets and went to the garage to check the final fit.
Everything bolted on easy and aligned perfectly.
The hub diameter is a tiny bit too small where the disc mounts so I made shims (for centering the discs) from a tin can.
Now the disc fits snug and is perfectly centered.
<P>
I designed the brackets so the calipers are mounted behind the axle but I found one of the bolts for mounting the calipers is not easy to get in with the steering arm in the way.
The mounting points are symetrical so I mounted the calipers in front of the axle, no problem.
Only thing I will need to check is clearance when I get tubular A-arms.
Martin
Martin71RS
04-23-2011, 11:21 AM
Made an update again
www.pro-touring.nl
click the Nova and go to page 8
Martin
63Duece
04-26-2011, 10:17 PM
very cool to see another First Gen 4DR ChevyII doing in PT style!
Martin71RS
06-26-2011, 09:00 AM
Made an update on the website.....wheels are on!
www.pro-touring.nl
click the Nova
Page 9
Martin
pjtimmer
06-26-2011, 11:42 AM
Looking good again Martin!
Take care
Pete
Martin71RS
11-05-2011, 10:56 AM
again some work done so a new update!
www.pro-touring.nl
click the Nova
Page 10
Martin71RS
02-08-2012, 02:03 PM
Again some work done the last few months...
www.pro-touring.nl
click the Nova
Page 11
454bug
02-09-2012, 04:47 AM
Very nice Martin! Did you design the mounting plates from scratch? If you did, that is VERY impressive!
With the caliper mounted in the front and the brake line mount in the rear, is there sufficient length in the flexible line when the wheels are turned to full lock? I was wondering if you might have to move the mounting point of the rigid line to the flexible line...
Those Novas look so funny with the 13" wheels on them! :)
Martin71RS
02-09-2012, 06:36 AM
Thanks Ray!
I did design the whole brake conversion myself...Above are the finished pics, I have more on my page (page 7 for the Nova), also shows my MDF templates and CAD drawing.
Since the spindles are symetrical (seen from the center line) I can mount the calipers front or back... I will need to test fit everything once I have my CPP a-arms and see what is the best solution, also regarding the brake lines.
I agree on the 13" wheels, the 17's look much better :-)
Martin71RS
04-01-2012, 01:42 PM
Kick panels are finished and more work done, made an update to my page.
www.pro-touring.nl
click the Nova
page 12
Martin71RS
05-14-2012, 01:29 PM
another update, got a lot done :)
www.pro-touring.nl
click the Nova
Page 13
Martin
Martin71RS
05-26-2012, 08:29 AM
and yet another update
www.pro-touring.nl
click the Nova
Page 14
Martin
Martin71RS
05-28-2012, 04:38 AM
Here are some random pics from my page...there I have described all steps including pictures, maybe nice for people that do not like to click on links :-)
https://static1.pt-content.com/images/pt/2012/05/wheels09-1.jpg
https://static1.pt-content.com/images/pt/2012/05/frontdisas13-1.jpg
https://static1.pt-content.com/images/pt/2012/05/kickpanels61-1.jpg
https://static1.pt-content.com/images/pt/2012/05/frontspindle08-1.jpg
https://static1.pt-content.com/images/pt/2012/05/cpparms07-1.jpg
https://static1.pt-content.com/images/pt/2012/05/pedalboxbolts14-1.jpg
Martin71RS
08-23-2012, 10:12 AM
update on the page, hydraulic clutch pedal and 62 4bolt rearend work/cleanup
www.pro-touring.nl
click the Nova
page 15
Martin
Martin71RS
12-17-2012, 07:07 AM
update on the page, new seats, T5 transmission install
www.pro-touring.nl
click the Nova
page 16
Martin
Martin71RS
05-16-2013, 10:54 AM
update on the page, T5 transmission install continued, x-member made and more.
www.pro-touring.nl
click the Nova
page 17
Martin
Martin71RS
07-21-2013, 11:44 AM
Got a lot done the last 2 months, some welding and electric power steering, so a huge update on my page:
www.pro-touring.nl
click the Nova
Page 18
Martin71RS
09-05-2013, 01:39 PM
didn't go on holiday this summer but made huge progress on the Nova!
www.pro-touring.nl
click the Nova
Page 19
Martin71RS
12-11-2013, 01:30 PM
Another update
www.pro-touring.nl
click the Nova
page 20
Martin71RS
05-21-2014, 09:21 PM
I just made an update to my page again
www.pro-touring.nl
click the Nova
page 21
(refresh it it does not show page 21)
https://static1.pt-content.com/images/pt/2014/05/backonitswheels09-1.jpg
Martin71RS
03-17-2015, 02:51 PM
I just made an update to my page again showing the GM Swiss built 64 4 door donor car I bought (special Beaumont trim) which has a factory original arm rest in the back seat....never seen that before? This should get my project moving again :-)
www.pro-touring.nl
click the Nova
page 22
(refresh it it does not show page 22)
Martin71RS
10-27-2015, 01:36 PM
New update finally.... bought a rotisserie to make my life easier and cut up 1 of the 2 cars.
https://static1.pt-content.com/images/pt/2015/10/rotisserie19-1.jpg
https://static1.pt-content.com/images/pt/2015/10/64bodycleanandrepair066-1.jpg
https://static1.pt-content.com/images/pt/2015/10/frontseats03-1.jpg
the whole story and this time 200 pics!
www.pro-touring.nl
click the Nova
page 23
(refresh it it does not show page 23)
Martin71RS
03-28-2016, 01:46 PM
I just made an update to my page again, made seat mounts, did some preparation for speakers and started rust repair....lots of pics
www.pro-touring.nl
click the Nova
page 24
(refresh it it does not show page 24)
Martin71RS
12-18-2016, 12:15 PM
I've been working hard the last few months on repairing the body, still not finished but here are some progress pics....
I guess I need to make an update on my page soon. :-)
Martin71RS
12-28-2016, 12:30 PM
making some progress :)
Martin71RS
01-06-2017, 01:10 PM
Martin71RS
03-24-2017, 02:08 PM
welded in some ground bosses
and started prepping the firewall for paint
meatonastick
03-24-2017, 06:59 PM
It's nice to see a 4 door getting some love
Martin71RS
05-09-2017, 11:19 AM
More progress :yes:
Martin71RS
05-19-2017, 12:09 PM
you can see the EPS motor under the dash...can't wait to test it.
Martin71RS
05-27-2017, 10:38 AM
did a lot of work the last few days.... finally it's standing on it's own 4 wheels again!
Martin71RS
06-04-2017, 05:58 AM
YES!!! everything electric is working again, I added backup lights and tested the EPS (Electric Power Steering)
click the link for video
https://www.facebook.com/martin.vanweerlee/videos/1371870892920558/
Martin71RS
06-11-2017, 06:30 AM
I finished wiring the car EPS electric power steering is now done (see previous post, movie!)
Also installed all wiring for the stereo so I had to test...put my kick panels in place, the look nice with the das all finished :yes:
click link for video
https://www.facebook.com/martin.vanweerlee/videos/1378956852211962/
Martin71RS
10-14-2017, 10:55 AM
mounted my kick panels (final) and speakers.... put the subwoofer box I made in and tested...
click link for video:
https://www.facebook.com/martin.vanweerlee/videos/1496151550492491/
ProTouring442
10-14-2017, 01:51 PM
What are the seats?
Martin71RS
10-14-2017, 09:43 PM
BMW E46 convertible (3 series) , they have the built in 3 point harness, leather and electric adjustable.
Martin71RS
10-20-2017, 08:55 AM
started with sound deadening....
Brakes are working (still need to test how well they work) and I've driven it a few metres back and forth.... clutch works very nice
Next week it's time to go to Vegas again...SEMA!!! (and of course the Pro-Touring.com dinner :-) )
Martin71RS
12-10-2017, 06:12 AM
After 1,5 year I have finally updated my website again....
450 pics and some movies
www.pro-touring.nl
click the Nova
pages 25 and 26
Martin71RS
04-03-2022, 04:08 AM
I'm sorry it took me 4 years, but I have finally updated my website again....
over 600 pics!
I am painting the car myself, using 2k spray cans (rattle cans) !!!
still not finished but definately getting closer :-)
www.pro-touring.nl
click the Nova
pages 27, 28 and 29
see it going from this:
198675
to now this:
198676
198677
198678
198679
David Sloan
04-03-2022, 04:58 AM
Love the more doors nova!
Looks good!
Martin71RS
04-09-2023, 01:29 PM
Made the first attempt at a test drive 3 weeks ago and that was a short one.... tires rubbed, exhaust scraped a speed bump and carb was terrible so it died after urning out of the street..... I just managed to get it back and started fixing things. Bought a quick ratio steering gear which is beter than the original 5 turn lock to lock and installed that, a remanufactured carb that makes it run so much better, new smaller width tires and I modified the exhaust. Today, Easter 2023 was the first succesful test drive!! Still need to finish the car but I am very happy right now :)
https://youtu.be/GozhfIbh384
David Sloan
04-09-2023, 03:44 PM
Congratulations my friend.
I’m so wanting to drive the Elcamino this summer.
