chevelle327c5
01-07-2010, 09:31 PM
hi
I was told to use the stock 68-72 booster and use a 2000 s10 master? how can that work? the rod on the booster that drives the cylinder in the master is at least 2" to long. if you look at a booster from a s10 it has a small little "nipple" (lol) that drives the master cylinder.
1.) Can u still use the 68-72 booster? if i would cut that shaft down? idk if that would still work? wouldn't that change the depth of the pedal?
2.) Does the 67-69 z28 camaro booster have a short plunger? if it did could i use that?
can you use camaro master from like a 98-02 or 93-97? I notice some people used a 95 camaro master and booster for a 67-69 camaro with a c4 conversion.
3.) If i had to use a late model booster.. would i be better off using a camaro booster from 93 to 02? If i did use one.. it looks to be a challange to mount up and get the "right angle"
4.) another ? is why a s10 master? If there brakes are to small to did a conversion?
Anyone have ideas on what to use or problem fix?
thanks
thanks
