View Full Version : Wider track width up front - results?
Tony_SS
01-06-2010, 01:36 PM
On my 86 C10 short bed, the front track with is about 1.5" wider than the rear. All C10's were setup like this, they came with rear-ends that were narrow. So since my wheel/tire setup is the same all around, the front wheel sticks out .75 on each side.
What effect handling wise does this have, if any?
monteboy84
01-11-2010, 12:40 PM
I can't speak to it for certain, but I believe they were built that way to reduce turn radius. The same idea is even more prevalent/obvious on some newer GM 4x4 stuff.
Apogee
01-11-2010, 04:01 PM
Almost all trucks (Chevy, Ford, Dodge, etc) are built with wider front track widths. When you turn, the rear tires cut inside the arc that the front tires travel...staggering the widths offsets some of that.
Tobin
KORE3
