View Full Version : TR6060 & LS3 into a 69 Camaro
NVR2L8
01-04-2010, 05:32 AM
Anyone have any comments or used the TR6060 trans yet? Know if it's a P.I.T.A. to deal with / install in an F-Body? This is sorta a repeat of a previous post of mine but I'm hoping for a little feedback before dropping any coin on a trans. I want to keep it a 6 speed and try to keep it as simple as possible AND not break the Bank in the process.
Again, Thanks for any replys.
Marc
Steve1968LS2
01-04-2010, 01:50 PM
You don't want to mess with a TR6060 (one out of a new car).. the remote shifter deal would be a PITA and there are other issues.
Now they do make a T56 Magnum which is the aftermarket version of the TR606.. that's what I have in my car.
Is that what you were refering to?
NVR2L8
01-04-2010, 03:28 PM
No, not exactly but I'm willing to consider any option. The TR6060 i mentioned is being offered at a very good price, $1,500 and thought I might be able to shoe horn it in.
Steve1968LS2
01-04-2010, 03:41 PM
It might.. but as you can see it's quite different.
The bellhousing is integral to the trans, that's not a big deal since you're putting it behind an LS3.
The remote shifter would be.. a challenge...
The way the driveshaft mounts to the TR6060 is different as well.. not the typical "yoke" deal.
I suppose it's possible, but hard enought for Tremec to offer a seperate aftermarket version (the magnum).. what is the TR6060 out of?
Here's the one out of a new Camaro.
https://static1.pt-content.com/images/pt/2009/12/1zdlmz6-1.jpg
NVR2L8
01-04-2010, 08:25 PM
The TR6060 I'm looking at is also out of a 2010 Camaro.
Steve1968LS2
01-04-2010, 08:32 PM
Then what you see above is what you'll have to contend with.
Think about the shifter arrangement and consider how you will mount a driveshaft.
The crossmember mount also looked to be different from the T56 Magnum.
NVR2L8
01-05-2010, 09:49 AM
Does not appear easy to incorporate into an F-Body Always a choise between $ and labor.
