View Full Version : Newbie Here!!
Rod
01-02-2010, 08:03 PM
I'm a newbie here and Currently building a 1968 Camaro with a few additions, I'm here to get a little tuning advice and:cheers: pass on some of the same
Suspension & Brakes;
Hotchkis 2" Front coils
Hotchkis 1.5" Rear Leafs
Hotchkis 1-1/8", Hollow Sway bar (front)
Hotchkis Machined Tie Rod Sleeves
Hotchkis Sub Frame Connectors
Hotchkis Rear Shock Tower Brace
Hotchkis Chassis Max Handle Bars
Hotchkis Premium Steering Rebuild Kit
Complete welding of all seams on the factory sub-frame (for strength) and then Glass shot peened to reduce torsional chassis stresses (Peen-Rite)
Global West aluminum body mounts and stainless sub frame bolts
Global West 6 degree Upper tube arms (Urethane bushings)
Ceramic Painted stock lower Arms with (urethane bushings)
KYB Gr-2 shocks front and rear
AGR 12.7:1 gear ratio Billet power steering box
Derale Power Steering Fluid Cooler
Magnefine Inline power steering Filter
SSBC drum to power disc conversion 4 wheel brake Kit
Hawk Performance's HP Plus disc brake pads
Corvette C5 wheels 17” front (2”spacer)18” rear (2.250” spacer)
Engine;
Seasoned, GM 350 engine Bored 30 over and surface Decked (010 4 bolt block)
ARP Main Bolts
ARP 134-7901 Oil Pump Driveshaft
Melling M55HV (high volume) pump with matching pick up tube for oil pan
GM heads Surfaced with 1.6 rocker arms
Victor Reinz performance gasket's
Holley Street Dominator intake
Edelbrook 1406 carb
Moroso Carburetor Spacer 1”
Holley Red Electric Fuel Pump
3/8" Stainless Steel Front to rear fuel line
1 5/8 in. Headers
Safety wired header bolts
2.5” Mandrel bent Aluminized Exhaust Front to rear with H Crossover
HITACHI Mini Starter (high torque)
Mallory Unilite distributor
Msd coil
Taylor 8.8 plug wire set
Prothane's poly urethane engine mounts and ARP engine mount bolts
ARP stainless engine complete bolt kit
Taylor spark plug wire holders
69 Camaro 4 Row Radiator
Aluminum over flow bottle
16” Electric cooling fan and aluminum fan shroud
Royal Purple Oil
Power train;
Richmond Super T-10 is a four speed (1st gear is 3.42, 2nd is 2.28, 3rd is 1.46, and 4th is 1 )
Prothane 7-1604 transmission mount
Red Line Trans fluid
621 bell housing
Zoom clutch
Centerforce Flywheel 168 tooth
ARP Chevy Flywheel Bolts
Hurst/Indy 4-Speed Shifter (7 1/2” tall shift arm)
Lakewood shift fork
Lakewood pilot bearing
Stock balanced Drive shaft with Currie Enterprises U-Joints
Factory 8.2 10bolt (3.08 ratio)
Trunk Mounted Optima Battery and NoCal Speed Shop Battery Mount
Interior and Exterior;
Scat Pro Car seats
Aircraft style seat belts
Talbot Vintage racing mirrors
Detroit Speed and Engineering 7 speed wiper kit
Detroit Speed and Engineering 68 RS electric headlight Door update kit
Billet RS grill kit
Tri-Bar Halogen headlights
LED front turn signals
Air Rides billet fuel cap systems
American Autowire Kit Classic update full car harness kit
Auto Gauge instruments
Cool IT thermo tec insulation
Southern rods hot rod heater (smoothed firewall) with custom single switch control
Grant GT steering wheel
https://static1.pt-content.com/images/pt/2010/01/DSC_5329-1.jpg
CruizinKev
01-03-2010, 02:42 AM
nice project! welcome aboard :twothumbs
1971CHEVELLE
01-03-2010, 09:41 AM
Welcome to the site
