View Full Version : Hi newbie from ny long island
1970 TT Rustang
01-02-2010, 06:05 PM
Hi all iam new here, iam from long island i have a 70 mustang fastback its twin turbo with a small block 427 with air ride and a ton of other parts still a work in progress. Iam looking forward to learning more from you all it just nice to know that theres other people in the same boat as i. We all are a rare breed when it comes to protouring, far and few in between.
L & H Kustoms
01-02-2010, 08:28 PM
Nice fastback I am just finishing a 70 fastback for a customer
CruizinKev
01-03-2010, 02:41 AM
nice! welcome aboard :twothumbs
Bryce
01-03-2010, 06:37 AM
welcome.
1970 TT Rustang
01-03-2010, 07:54 AM
Thanks everyone
1971CHEVELLE
01-03-2010, 09:39 AM
Welcome to the site
DarkBuddha
01-12-2010, 11:01 AM
I can't believe I missed this, but welcome to the sight! I have to say I'm super curious about the turbo setup... more details and pics of the exhaust and mounting would be awesome!!!
1970 TT Rustang
01-12-2010, 01:21 PM
Well its a 351w bored out to a 427 it made 525hp on 87 pump on a engine dyno. i got remote mount twin 60trims kooks headers tial dumps air ride ssbc brakes haltec ecu witch iam switching as we speak i have a currie rear with 373. Two speed gear vendors unit and more if you have some questions let me know heres some pics. it made 680 rwhp at 18psi the cam needs to be changed and it needs a thicker head gasket
1970 TT Rustang
01-12-2010, 01:23 PM
heres some more. O by the way you car looks real good, it a real nice cruizer. i love the rally lights what color do you got there?
ponchopwr70
01-12-2010, 01:45 PM
Welcome very cool car!
DarkBuddha
01-12-2010, 09:01 PM
Dude, that is some serious f'ing stuff right there! Way beyond my current (or even future) aspirations for my Mach. I'm thinking maybe doing something a bit simpler (and cheaper) and doing a pair of flipped manifolds and a pair of Turbocoupe IHIs underhood. That said, you're install looks fantastic and is clearly very very functional.
And if you were asking about my Mach's color, it's just the original Bright Gold Metalic in a modern base/clear. My car is a bit of a compromise in terms of goals and realizations. I always intended the car to be a daily driver, never a show car, but I've done quite a bit of budget stuff to it and stuff that isn't so obvious. I'd love to do AirRide, but I could only afford a Pro-motorsports A-arm drop kit and some mid-eye leafs. I'd love a 31 spline 9" lsd, but I can afford the stock 28 spline open 9". I'd love Baer brakes all the way around, but I can afford stock front discs and a Mk VII rear disc conversion. You see what I mean... which is why if I do a turbo conversion, it'll have to be modest budget oriented too.
Thanks again for the pics and info... very inspirational.
1970 TT Rustang
01-13-2010, 08:26 PM
No problem. love your ride:1st:
MK70
01-24-2010, 03:10 PM
Vert cool car. I would think the rear mounted turbos would mean a lot of lag. But then again, 427 cubes probably take care of the low end torque.
GrabberGT
03-31-2010, 12:00 PM
Im in the planning stages for my remote mount turbo setup. Would you mind to terribly if I duplicate yours. If not, would you post up specifics. Turbo size, wastegate, BOV, oil system... Any regrets? I've got a 347 so I imagine my turbos would be a little smaller.
1970 TT Rustang
03-31-2010, 12:49 PM
yea iam takeing the turbos off and going all motor for now. The motor was rated for 525 with a carb i got FI now so it should still be a quick ride at 2800 pounds its a bill mitchell motor a 351 stroked to a 427. Iam thinking about some head porting pistons and a procharger in a few years. I want to change the color and and do a new set of wheels. My turbo setup is for sale now. its twin garretts 60 trims tial wastegates iam running one oil pump per turbo and a oil cooler. I wish this hole setup was planned better the turbos were a after thought my motor can handle just under 1000hp but the cam is wrong and should have diffrent lifters the compession is to high the pipeing should of been more well thought out. Its some what of a headache if i went with a procharger off the bat i would of saved 10s of thousands. But at the same time when iam cruseing and i jump on it traffic stops it sound like a hellbent 18 wheeler!
GrabberGT
03-31-2010, 01:07 PM
Love it! I want one. How much are you asking for everything but the piping?
1970 TT Rustang
04-02-2010, 05:04 PM
i was thinking about 1000 for the turbos wastegates oil pumps and intercooler
GrabberGT
04-03-2010, 03:30 AM
Sounds like a hell of a bargain. But.... after more thought and research, those 60's are a little big for my setup and the IC will likely not fit in front of my corr support and condenser. Thanks anyway and good luck with the sale.
What oil pumps are you running?
1970 TT Rustang
04-03-2010, 01:45 PM
ok no problem
BirdsThaWord
04-03-2010, 02:24 PM
Welcome! Sick ride you've got there!!!
windsor
04-08-2010, 07:55 AM
awesome!
Didn't see what kind of tranny you are running?
