View Full Version : NEW RideTech Modular Sway Bar
darren@ridetech
12-18-2009, 12:44 PM
Rodney just finished development on the new MuscleBar sway bar for the front of the 78-88 GM "G" Bodies (Monte Carlo, Cutlass, Malibu, Regal, GN). This bar uses a modular design similar to out Imapla, Chevelle, and Camaro Musclebar. It also utilizes the PosiLink enlinks to eliminate freeplay associated with conventional poly bushing endlinks.
http://www.ridetech.com/shop/index.php?dispatch=products.view&product_id=6477
https://static1.pt-content.com/images/pt/2009/12/attachmentphpattachmentid530stc1d1261169-1.jpg
https://static1.pt-content.com/images/pt/2009/12/attachmentphpattachmentid528d1261167004-1.jpg
https://static1.pt-content.com/images/pt/2009/12/attachmentphpattachmentid529d1261167008-1.jpg
Twentyover
12-19-2009, 08:29 AM
Ao the arms are bolted to flanges secure to the bar?
darren@ridetech
12-21-2009, 05:10 AM
Yes the arms are attached to the flange with 3 3/8" Allen bolts. It's located by the end of the tube.
nowukno
12-21-2009, 05:59 PM
Sweet!! Are shorter links available for cars with lower ride heights??
TT302Z28
12-21-2009, 06:58 PM
What specific benefits will this give me? Wider tire less rubbing? Better sway bar spring rate?
darren@ridetech
12-22-2009, 08:15 AM
This bar was designed on our StrongArms with a 2" drop ride height. So you should be fine. The sway bar mount location on the StrongArms is the same as factory, so fitment is possible on other arms but we have not test fit them yet.
darren@ridetech
12-22-2009, 08:24 AM
I know on the A Bodies we gained a fair amount of tire clearance. We were able to run a 10" whell w/ 275's. Not sure on this car yet. I'll find out though, and report back.
Uses a 1.5" diameter .188" wall tubing
The PosiLinks eliminate the poly bushing, so you are always on the bar, not compressing the poly.
It looks cool..... :)
nowukno
12-22-2009, 02:42 PM
This bar was designed on our StrongArms with a 2" drop ride height. So you should be fine. The sway bar mount location on the StrongArms is the same as factory, so fitment is possible on other arms but we have not test fit them yet.Thank you Darren
ScotI
12-24-2009, 07:35 PM
What specific g-body are you guys testing on? What wheel width & BS-ing?
796spdbu
12-29-2009, 05:39 PM
I am also interested n knowing the specs on wheel and tire combo?
amanzo00
08-06-2012, 04:25 AM
Has anyone intstalled the on an 85 monte carlo ss?
