View Full Version : 69 Fbody
firebob
12-15-2009, 11:12 AM
Fbody rear disc
Installed the SSBC kit yesterday.
Couple of issues:
1)I haven't cut in the adj prop valve yet. Do I need one?
2)Do I need to remove the orig hold off valve from the front line?
3)The ebrake cable...I need a longer one on the pass side, The kit came with a short extension cable but I have no idea how they figured this thing would be used. Anybody know of a cable I can pull from a wrecking yard that will give me the right length?
Robert
Apogee
12-15-2009, 05:12 PM
My $.02 for what it's worth:
1) Yes, install an adjustable proportioning valve. It will work without it, but should work better with.
2) You don't need to remove the OE hold-off valve, however you don't need either. It isn't doing anything beneficial in a disc/disc system.
3) I don't know...hopefully someone else can be more helpful on this one.
Tobin
KORE3
firebob
12-15-2009, 06:57 PM
Update:
I went scrounging today. Since the calipers SSBC uses for this kit are Tbird, I looked at the Fords and pulled a cable off a 96 Taurus(driver side)($16). Fit is good. I may go back and get another for the other side tomorrow.
I tried to unbend the loop in the original brake line on my car to install the adj prop valve and of course it snapped so I have to go buy a tube nut tomorrow and make a new flare. BTW The instructions say install it after the dist block if it has an integral switch.
More to come if anybody's interested.
Robert
