View Full Version : GMR - LR Dimple Dies
The GMR
12-15-2009, 10:09 AM
https://static1.pt-content.com/images/pt/2009/12/yhst94167679943066_2082_3735925-1.jpg
These dimple dies are the absolute best in the industry. They are used by the best builders and fabricators to add some serious style and strength to any sheet metal component. Made from hardened 4140 they will last a lifetime.
https://static1.pt-content.com/images/pt/2009/12/yhst94167679943066_2082_10782637-1.jpg
Available online at theGMRstore.com
http://www.thegmrstore.com/dimpledies.html
If you would like to order by phone or have any questions please feel free to contact us at the shop. 562-595-5410
jason
TT302Z28
12-21-2009, 07:00 PM
Please forgive a likely lame question...I have never used these before and was thinking that you use a press to push the top dye to the lower?
skatinjay27
12-22-2009, 01:32 AM
yes thats how they work...
Yelcamino
12-22-2009, 04:17 AM
What if you don't have a press? Can you use a large bolt and nut?
Mike Holleman
12-22-2009, 05:56 AM
Order you a set Herb. You can keep them in my shop and use my presses anytime you like.
The GMR
12-22-2009, 02:27 PM
depends on the material your are going to dimple. For some of the thinner material that will work, an impact with grade 8 bolts.
We suggest a simple 20 ton press. I have one here in the shop and we have been using it for years now.
jason
The GMR
12-22-2009, 02:29 PM
here is a step by step on the dimple dies.
STEP 1
Cut a hole to the desired size. This hole
needs to be cut to the desired with of the
dimple die.
Ex. IF you are using a 1.5" die then you
need a 1.5" hole.
Step 2
Place the hole in the material on top of the
male die and slide down until it rests on
the slanted forming part of the die.
Step 3
Place the female die over the male die and
slide down to sandwich the material between
the dies. Make sure the female die seats
properly on the male die before pressing
down.
Step 4
Press the female die and the male die
together to create the dimple, a 20 ton or
greater press for this.
Step 5
Remove the female die and pop the male die out of the material . The dimple is now complete.
Yelcamino
12-22-2009, 04:46 PM
That sounds like a great idea Mike, but it would probably be cheaper for me to buy a press than to drive back and forth to your place! :drive:
Yelcamino
12-22-2009, 04:47 PM
jason
After looking at your step by step pictures, I didn't realize the dies are so big! I guess a nut & bolt would be a pretty tough way to go!
Kenova
12-22-2009, 06:30 PM
Keep in mind that the holes shown appear to somewhere around three to four inches in diameter.
With smaller holes and thinner material, the bolt and wrench method may work.
:idea: Hey, pound the snot out of them with an old cylinder head! Just kidding of course.
Ken
796spdbu
12-23-2009, 02:31 PM
The dies come in all sorts of sizes. Those looked to be 3"-4"
The guys on pirate4x4.com and dezertrangers.com use all different sizes.
Thay use them on axle brackets and chassis stiffeners
The GMR
12-31-2009, 02:23 PM
Quite a few orders over the holidays. Thanks guys! :)
Jason
Mr.VENGEANCE
12-31-2009, 05:16 PM
Johnny C.
02-19-2010, 01:55 PM
I would love to have a set of these.
elitecustombody
02-21-2010, 06:26 PM
Jason, do you offer lifetime warranty on the 5-piece die set?
The GMR
02-21-2010, 09:30 PM
The warrenty is issued through the manufacture Light Racing.
We have only had one die break, it was a 3/4 die and the operator accidently used a 120 ton press at abou 80% capacity when he was directed not to do so.
Ive had the same set in out fabrication department for about 6 years now.
jason
elitecustombody
02-22-2010, 05:42 AM
Great to know that they can take a beating, I'd have to pick up a set, I just wish slightly bigger dies were more affordable
Stefan
tankhunter
02-22-2010, 07:51 AM
these are cool
