View Full Version : GMR Full Floater Hub Setups
The GMR
12-14-2009, 11:30 PM
https://static1.pt-content.com/images/pt/2009/12/yhst94167679943066_2085_756184-1.jpg
These Full Floater hub setups are the perfect addition to your GMR rear end housing. Made in the USA they are designed for reliability.
Benefits of a Full floating System:
A full floating rear end setup reduces the stress on the axles and internals. The hub and weight of the vehicle is on the snout which is welded into the housing. The axles are now subject to rotational forces only, instead of both vehicle weight and rotational force. Each hub utilizes two large Timken bearings with seals and locking nuts to secure it to the snout. Another added benefit is the ability for the vehicle to roll without axles or internals. During the build process this can be very useful.
Options:
28 or 31 Spline
Bolt Patterns- 5x5, 5x4.5, 5x4.75, 5x5.5, and 6x5.5
Rotors- 10 or 11 inch
Hub Kits Include:
2 hubs
2 Dive plates
2 Snouts
4 Bearings
2 Seals
2 Rotors
2 Axle Caps
2 Lock Nuts
4 Races
Wheel stude included
Screws Included
Prices Starting at $450 online at theGMRstore.com
28 spline - http://www.thegmrstore.com/28spfuflkit.html
31 spline - http://www.thegmrstore.com/31spfuflkits.html
https://static1.pt-content.com/images/pt/2009/12/yhst94167679943066_2082_7395191-1.jpg
Jason
The GMR
12-31-2009, 02:24 PM
Just added More items to the online store for these.
http://www.thegmrstore.com/31and28sphua.html
Jason
Bryce
12-31-2009, 03:29 PM
those look very nice. Do you do all fabrication/manufacturing in house?
The GMR
12-31-2009, 03:58 PM
We do not machine items in house. All the welding and assembly is done is house along with any fabrication work.
jason
Bryce
12-31-2009, 04:52 PM
do you have the ability to make a custom frame. Full tube chassis. I would do the complete design. This was just a passing thought as I am not a that stage yet. But i working on my own chassis. I am designing it all in CAD. so any easy export to a tube bender.
The GMR
12-31-2009, 05:33 PM
Yes we can, we have a full frame/ fixture table with over 500 1/2" bolt holes in it on 3" center. We also have extensive cad abilities. Our new kit car chassis, the GMR-ONE is fully CAD designed then all plate/ tube is completely CNC lasercut. Let us know when your ready, our fab shop can fit about 6 chassis in there. :)
jason
Bryce
12-31-2009, 05:45 PM
where are you guys located? I am in san diego.
The GMR
12-31-2009, 06:47 PM
Long Beach area right off the 405.
1452 E 29th
Signal hill CA 90755
jason
