View Full Version : GMR Ford 9" Rear End Housings
The GMR
12-13-2009, 11:35 PM
The Challenge-
In a world of Mass production, how can one Rear End Housing Stand Out?
The solution-
Each GMR Rear End Housing is built by a single professional GMR technician, ensuring that the passion and focus of one technician stays true throughout the GMR tagged product. The result of this is a truly hand crafted housing that flirts with something you might consider Art. Right down to every inch of weld, the GMR Rear End Housing is constructed with the utmost in quality and care. With three inch main tubes and a twenty four inch face plate this housing unit is built for track conditions yet weighs less then a stock Ford 9 inch housing. With a variety of options from Full Floater Race setups to everyday drive ability units The GMR has the setup your looking for.
The results-
3” by .188 main tubes
24” face plate
Precision designed internal gussets
Increased Oil Capacity
Unlimited applications
The GMR “Handshake Guarantee”
Accepts all stock and after market Ford 9” Members
Available with Full Floater Hubs or Big Bearing ford ends
Mig welded units starting at $500
TIG welded 4130 units starting at $1100
Online: http://www.thegmr.com/PTDrearends.html (http://www.thegmr.com/PTDrearends.html)
Order online: http://www.thegmrstore.com/3inchhousing.html
GMR L.L.C.
562-595-5410
Jason
The GMR
12-13-2009, 11:38 PM
TIG Welded Housings.
Each 4130 Chromoly TIG unit is double weave welded using Stainless 308 rod for superior strength and beauty.
Jason
The GMR
12-13-2009, 11:40 PM
MIG Welded units.
Jason
Bryce
12-14-2009, 06:30 AM
That is a very nice looking piece. Good price too. Do you have the capabilities to make it a bolt on combo? jig welded leaf pads and/or for control arms?
Too bad i recently bought a bare 9" currie housing.
Also the link in your signiture doesn't work for me.
The GMR
12-14-2009, 08:29 AM
We do have the those options available. We can weld on the perches for any width and degree for a variety of applications.
Here is a build of a notch back with a fiberglass leaf setup.
https://www.pro-touring.com/forum/showthread.php?t=60200
Were working on the link mounts right now, our new chassis will have the link setups.
Thanks for the heads up on the signature. I will fix that right now.
jason
Bryce
12-14-2009, 08:35 AM
Cool.
Motorcitydak
12-14-2009, 03:41 PM
Good timing, what would a full floating axle complete with hubs and axles cost? 5x4.5 BP, not sure what the width will need to be yet.
The links at the bottom of your page for the housing packages and axle ends do not work
The GMR
12-14-2009, 04:51 PM
The setup your referring to is our Stage Two package. This includes the housing, hubs, snouts welded in, filler welded in, drain welded in, and axles with drive plates. I will have more information up tonight or tomorrow.
31 spline FF MIG setups start at 1480
31 spline FF TIG setups start at 2080
Im working on the site tonight, thanks for the heads up. Good thing we build cars and not websites....:)
Jason
Yelcamino
12-14-2009, 06:18 PM
Boy those are some nice looking housings. Maybe one day down the road I'll need one and now I'll know where to look!
The GMR
12-16-2009, 06:34 PM
Here are some pics of the 31 Spline Full Floating snouts welded into a GMR housing.
TIG, again we use a double weave pass with stainless rod on the 4130 housing.
MIG, high heat and .035 ER70S wire make for a great weld.
Jason
Damn True
12-16-2009, 06:37 PM
Nice looking work.
The GMR
01-05-2010, 10:51 AM
I would like to thank those who ordered over the holidays. Your units are getting built this week!
also, to answer some questions, YES we will be coming out with semi-floater packages as well.
jason
The GMR
01-09-2010, 08:44 PM
New GMR9 Leaf Spring Perch.
http://www.thegmrstore.com/gmlesppe.html
Jason
MoparCar
01-10-2010, 06:46 AM
Do you have additional pictures of your 3 Link set up shown on the mustang? What 3rd link bracket are you using (single hole, double, etc. for adjustment)? Can this housing be purchased with a custom housing width, customer specified center to center on the LCA shock mounts, and a pinion offset with the 3rd link mount welded for a Johnny type joint. Also if available, what width of joint do the LCAs accept?
Nice looking product. I'd be looking at a non floater standard type MIG housing.
Thanks, Wes
The GMR
01-10-2010, 09:38 AM
Thanks, Wes
Wes,
I do not have any more pics of that setup, I lost most of the images when our main computer crashed. I do however have the design files still. The upper 3 link mount is a dual bolt hole setup for a 3/4" on 1/2" bore heim. The lowers have multiple bolt holes for adjustment, with 3/4" on 5/8" bore heim.
All the housings are made to order, so a specific width is not a problem. We offer them online in many different widths or you can call the shop and order a specific number that is not listed.
If you are looking for something more custom, we can certainly do that. We are a full fabrication facility so custom items are not a problem, you just need to place the order by giving us a call. From the pinion offset to the custom link mounts we can build it to your specs.
thanks,
Jason
MoparCar
01-10-2010, 10:42 AM
Jason,
Thanks for the quick reply. The does open up some nice options for a 3-link. This is a street car so I'm leaning towards a rebuildable type Johnny /Spohn/Ballistic type joint.
Thanks, Wes
The GMR
01-15-2010, 08:28 AM
Click the link below for the Pro-Touring.com Specials!
https://www.pro-touring.com/forum/showthread.php?t=64186
Jason
