View Full Version : FREE Wilwood Master With Total Car Brake Packages
ProdigyCustoms
11-25-2009, 10:23 AM
March 23, 2010 We are doing it again! More FREE Polished or Black Tandem Master While Supplies Last.
This turned out to be a HUGE promotion so we are doing it again!
Prodigy Customs Total Car G-Machine Brake Packages
ATTENTION: While Supplies Last
FREE POLISHED OR BLACK WILWOOD TANDEM MASTER UPGRADE, $200 VALUE IN OUR KITS. THIS IS the $239 POLISHED OR BLACK MASTER CYLINDER!
POLSIHED
BLACK
Prodigy Customs introduces our Total Car G-Machine Brake Packages for Camaro, Chevelle, Nova, F body, A body, G Body, Ford, Mustang, Mopar and many others featuring the worlds best brakes, Wilwood Disc Brakes! Prodigy Customs EXCLUSIVE Total Car G Machine Brake Packages takes all the guess work out of your 4 wheel disc brake conversion. Our kits include front and rear Wilwood brakes in the size of your choice, front sizes from 10.75" - 14.25" rotors for all popular applications, Rear brakes include INTERNAL E BRAKE in sizes from 12.2" to 14.25" for all popular applications. Calipers are available in Four Piston to Six Piston, Dynalite and Superlite Calipers Our exclusive Total Car G-Machine brake packages include everything required to convert you original brakes to monster 4 wheel disc. Call for your exact application.
Kits include:
Wilwood Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Front Braided Brake Hoses
Prodigy Customs Rear Braided Brake Hose
E brake Cables for Internal E Brakes
Corvette Style Master Cylinder
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
10.75 to 12.2"F / 12.2" R kit is $1800
NOTE:
($1800 Kit includes BLACK CALIPERS and NON Drilled / Slotted Rotors)
Upgrade cost are and are added to base kit price of $1800
Upgrades include:
(6) piston Dynapro front caliper upgrade (12.2" kits only) $300 option
13" (6) piston Superlite front upgrade $800
14" (6) piston Superlite front upgrade $1000
13" (4) piston Superlite rear upgrade $700
14" (4) piston Superlite rear upgrade $900
Drilled and Slotted Rotors are $200 Option
Red, Blue, Yellow, Silver and Polished Calipers is $200 Option
Wilwood Aluminum Dual Reservoir Master Cylinder (Plain) is $170 Option
Wilwood Aluminum Dual Reservoir Master Cylinder (Polished) is $200 Option (FREE While Supplies Last)
Wilwood Aluminum Dual Reservoir Master Cylinder (Black) is $200 Option (FREE While Supplies Last)
8" Dual Diaphragm Polished Stainless Power Brake Booster $200
Base Total Car G Machine Brake Package with 12.2" F (4) piston Dynalite / 12.2" R (4) piston Dynalite kit With Standard Black Calipers / Standard Smooth Rotors ONLY $1800
As Shown With Upgrade Otions:
RED CALIPERS,
DRILLED AND SLOTTED ROTORS,
POWER BOOSTER
AS SHOWN IS $2400.
13" (6) Piston Superlite Front / 13" (4) piston Superlite Rear
Extreme Total Car G Machine Brake Package with 14" F (6) piston Superlite / 14" R (4) piston Superlite kit With Standard Black Calipers / Standard Slotted GT Rotors ONLY $3700
As shown with Upgrade options:
BLUE CALIPERS,
POLISHED WILWOOD MASTER (Free While Supplies Last)
AS SHOWN IS $4100.
Custom pedal set NOT INCLUDED
ProdigyCustoms
12-16-2009, 07:45 PM
Bringing this to the top. Still have a dozen more FREE Wilwood Tandem Master Cylinder upgrades available.
Remember, these kits are complete with EVERYTHING but hard line including Wilwood DOT 4 fluid, Safety wire, safety wire pliers, our very own custom braided rear hose, E brake Cables, Front braided hose, prop Valve and master cylinder.
bgray
12-20-2009, 06:47 AM
Hey, Im currently trying to source a kit for my 72 nova. Will all this work with my factory power booster? Im running 18" bonspeeds and DSE front suspension, any fitment issues i should know about?
Im really looking for a kit that is engineered to work as a set, and have no issues...is this the kit?
have any pictures of the upgraded caliper options?
thanks
ProdigyCustoms
12-20-2009, 07:44 AM
This is your kit. We thought of everything including the special tools for assembling the rotors properly which would cost you $75 if you tried to buy them. Like I said above, we include everything but the hard line.
Yes we can use your factory booster. As long as your engine is making enough vacuum (re: No real big camshaft) we can reuse your factory booster.
Here is a picture of the DynaPro 6 caliper on the 12.2" set up. We can also do a Dynapro rear caliper to by special order.
bgray
12-20-2009, 09:11 AM
This is awesome. What do i get when I do dynapro rears? whats the advantage?
Whats my price for Black Front and Rear, Upgraded dynapro fronts, complete kit...My car has a factory crate motor 290hp gmpp engine. I will be running big cam and heads when i do the ls2 swap, but plan on doing hydroboost anyways..down the road
ProdigyCustoms
12-20-2009, 09:40 AM
There is zero advantage to the Dynapro rears except bling of a big caliper! The front DynaPro 6 add $300 to the $1800 kit. And your choice of the polished or black master.
bgray
12-20-2009, 09:43 AM
what comes in the kit currently in the rear? The calipers pictured in the fuirst picture? 2 piston?
ProdigyCustoms
12-20-2009, 10:01 AM
Those are (4) piston Dynalite calipers.
BTW, there is no such thing as a DynaPro (4) piston caliper. There are some other incorrect advertisments around incorrectly calling (4) piston Dynalite calipers a (4) piston DynaPro caliper, but there is no such thing as a (4) piston DynaPro Caliper. There are 2 sizes of Dynapro (6) calipers for specific front and rear applications, but no Dynapro (4) piston.
Here is the (4) piston Dynalite rear kit
bgray
12-20-2009, 10:09 AM
awesome..so what do you need from me to order? any specific measurement setc from my car?
ProdigyCustoms
12-20-2009, 01:32 PM
Nope, we take responsibility for the fitment. Just give me a call. I am available today 12PM to 8PM Eastern, Monday thru Weds 8AM to 8PM eastern, Thursday 8AM to 12PM
four zer seven 832 1752
bgray
12-20-2009, 01:56 PM
I'll give you a call tomorrow and well sort it out
bgray
12-21-2009, 06:47 AM
ordered. Frank knows what hes doing. Rec this seller to all members
ProdigyCustoms
12-21-2009, 07:46 AM
Thanks man, you got in on a killer deal.
Merry Christmas
GeoffP
12-21-2009, 08:57 AM
I wholeheartedly recommend Frank and crew. He hooked me up last year with the 12.2 kit and I got the very first set of DynaPro 6 piston calipers. I can attest to the stopping power if there's any question about how well this system stops.
bgray
12-21-2009, 09:46 AM
lol, i know. Hence why from seeing the deal, within 24 hours i ordered it! lol
Chicken Louie
12-21-2009, 05:33 PM
Frank,
What do I need for a 67 firebird running the AFX spindle package and and a Ford Nine (with a chev bolt pattern) with parking brake and a Master cylinder to match up with a Hydroboost. Running 18" Rushforths, so I wouldn't mind running the 13" brakes.
ProdigyCustoms
12-21-2009, 09:08 PM
You will have to run at least a 13" kit on those spindles. I would do a 13" (6) piston Superlite front and a 12.2 (4) piston Dynalite rear. If you want to bling it up we can do a (6) piston Dynapro caliper on the rear specially designed with smaller pistons for rear brake applications.
13" (6) Piston Front Kit
12.19 (4) Piston Dynalite Rear Kit
Optional Rear DynaPro Caliper
With the POLISHED or BLACK Master included, and the Safety wire, pliers, and our own custom rear hose we have made, and all the other Wilwood parts including E Brake Cable, Braided hoses, Prop Valve, Wilwood DOT 4 fluid, is:
13" (6) piston front and 12.19" (4) piston Rear WITH internal E Brake, all Drilled and Slotted is $2800. Add $300 for (6) piston rear DynaPro caliper
This is a truely killer brake packge for right at 3 grand.
4086D9
01-28-2010, 10:23 PM
Frank,
Will the 12.2 rotors and 4 piston dynalites work with some 15x3.5 weld draglights?? They have a 1.75" bs.
ProdigyCustoms
01-29-2010, 04:03 AM
You woul have to run a small wheel adapter. that is what i am doing on one of my special projects. Lots of room to push the wheel out, so i am using a 1 1/2" adapter when i run my drag skinnies.
$Mike70Z-28
01-29-2010, 04:16 AM
frank what is the price on just the calipers DynaPro 6 caliper on the 12.2" set up in red
ProdigyCustoms
01-29-2010, 06:13 AM
If your Dynalites are new I will trade them in.
Hit me on the email, I will make it work for you
[email protected]
$Mike70Z-28
01-29-2010, 07:07 AM
hi frank my Dynalites are not that new they been on the car for like 2 years but driven only in the summer thanks mike
ProdigyCustoms
01-29-2010, 08:42 AM
I could have done a nice trade deal for new ones.
I sent you a deal.
4086D9
01-29-2010, 09:33 PM
Shoot I was thought they would fit. What is the largest set up I can use on the front with the 15x3.5's with 1.75" bs with no adaptors.
Thanks!
Vegas69
01-29-2010, 09:46 PM
Thanks!
So you buy your wheels through Prrc but you lean on Frank for advice. I've recently lost all my respect for you.
ProdigyCustoms
01-30-2010, 06:34 AM
Thanks!
We have a 11" set up that will fit. But running the adapter is no big deal either
4086D9
01-30-2010, 10:48 PM
Thanks Frank I was lookimg at the wilwood site but man they have so many set ups on there its hard to figure out what is what.
ProdigyCustoms
01-31-2010, 06:58 AM
No one knows these systems in and oout, and what is available like we do. We move so much Wilwood product through the line for these cars, we are touching it everyday.
The 11" kit is something we just got.
Bryce
02-01-2010, 09:10 AM
the 11.75" kit for fords with the .47" offset fits my 15x3.5 skinnies just fine.
dkhonda400
07-08-2010, 11:43 AM
Does the kit does not come with a power booster?
ironcampig
08-22-2010, 05:31 PM
Hey frank make me a deal on 6p brake kit
this is Ed from California
ProdigyCustoms
08-23-2010, 03:13 AM
Ed, give me a call.
