View Full Version : Frame rail questions
rlplive
11-24-2009, 07:42 PM
Ok guys. I know my car has been hit in the left 1/4 panel. The floor board is crinkled up, and the frame rail is definitely tweaked. The frame rail is also pretty rusted out. I am pretty sure it is going to need to be replaced. Here are my questions. Should I have the car put on a frame rack before I proceed with any metal replacement? I am planning on replacing the entire floor pan first. My other questions is this. When do you replace the frame rail? Do I need to replace the floor and trunk pans before I replace the frame rail so I have something good to weld it to?
I am a novice at this, although I am planning on trying most of this stuff myself. I have a hobart welder and a lot of courage. thanks
Ryan
mikey
12-06-2009, 08:20 PM
Definately put it on a frame rack first just to make sure that it is square. I would reccomend a shop that has a Chief genesis measuring system it's way more accurate than the old center line guages. The charge will ususally be around 2 hrs for setup and measure. Most likely around 50-55 per hour. I would do the floor first then do the rail and trunk floor at the same time. Just pm or call me if you need any help.
Mike
rlplive
12-07-2009, 05:41 PM
Thanks as always Mikey. I am sure I will be contacting you. I will call the place here in town and ask what system they use.
