View Full Version : master cylinder leaking ?
68rag
11-22-2009, 01:36 PM
I have just finnished ground up on 68 camaro . I took it out yesterday and found that I was loosing fluid out of the master . The cap and gasket are fine and tight , could i be getting preassure in the master that would force fluid out of the top ? I am running wilwood dynalite 4 piston on all 4 corners and a 7 " booster and master from ccp dot 5 fluid ?
Apogee
11-25-2009, 03:13 PM
You say the cap and gasket are "fine and tight"...so is that where you're losing fluid? If so, that doesn't sound fine, even if it is tight. Which MC from CPP are you using? Any pics to share?
Tobin
KORE3
