View Full Version : Converting from auto to manual pedals...same mounting bracket?
ed1le
11-22-2009, 08:29 AM
I'm converting my 'lark to a 6-speed and looking at manual trans pedals. Will factory 4-speed pedals mount to the automatic mounting bracket or will I need to get a new bracket as well? Looking on ebay and such, I see a lot of clutch/brake pedal assemblies but no mounting brackets.
Samckitt
11-22-2009, 08:36 AM
Not sure about your case, but in mine, the manual pedals used the same bracket as the auto.
Randy67
11-22-2009, 12:32 PM
The bracket should be the same. It was on the 71 Camaro I converted. I did get the bracket with the pedals and it was the same as the auto bracket.
ed1le
11-25-2009, 06:38 AM
I've confirmed that the bracket is the same. Chevelle pedals, however, are different than skylark, cutlass or lemans. Chevelle uses a slide pin, the others bolt in. No biggie, found a set of buick pedals so I'm set!
