View Full Version : II Much clutch pics
parsonsj
04-12-2005, 03:07 PM
I've been working with the guys at Quarter Master on a clutch for my project. They specialize in lightweight, yet strong driveline components. Given the car's weight (about 3000 lbs), hp level (hopefully my 427 LS2 will make in excess of 650 hp), QM came up with a brand new clutch.
It's a dual disc, 8.5" diameter setup. They sell lots of 5.5" or 7.25" clutches for racing use, so the 8.5 is a little different for them. It has organic material, and a sprung hub to make it less "binary". The flywheel is scalloped on the back to reduce weight. The whole setup weighs in at just under 30 lbs. Check out how the inner hub connects the two discs together. It's a much better design than having both discs spline onto the tranny input shaft (which can result in a twisted input shaft between the clutch plates).
jp
quadfather
04-12-2005, 03:29 PM
sweet set up . what did that cost?.
parsonsj
04-12-2005, 03:46 PM
Hey quad. Yes, QM makes some very trick parts.
I'm not sure how much they'll want for one. Their racing versions (5.5, 7.25) go for around $800.
jp
quadfather
04-12-2005, 04:22 PM
that sounds resonable for a peice like that one. let us know when you find out. thanks
andrewb70
04-12-2005, 05:26 PM
The dual disk 8.5 will run probably more in the 1200-1300 range, with the billet flywheel.
parsonsj
04-12-2005, 06:17 PM
Yeah, I guess the racing prices I looked at didn't include the flywheel.
jp
MuscleRodz
04-12-2005, 07:17 PM
Is that clutch design for all their clutches or just that particular one? I am still up in the air on a clutch for my LT-1 w/ ZF-6 speed. I don't need to radical of a setup but better than stock. I have been looking at Centerforce DF clutches and McLeod but can't make up my mind.
Mike
parsonsj
04-12-2005, 07:52 PM
Mike,
I believe the spline drive for the discs is unique to this clutch.
jp
