View Full Version : 1967 Barracuda Fastback
1967Barracuda
11-19-2009, 08:10 AM
Heres my 1967 barracuda fastback, Its a slant 6 automatic Im im planing on doing a 5.9L 360 Magnum, viper T56 6 speed, and 8 1/4 rear end.
So far i stripped the entire car, except for the underchassis and enginge compartment to steel, then i primered it. Im about to begin the sheet metal work.
Heres my progress so far...
1967Barracuda
11-19-2009, 08:16 AM
Heres more pictures, as far as the suspension goes, I'm planning on Road Race leaf spring from Firm Feel, a 1973-1976 Abody V8 k-member, Front and rear sway bars, Dodge viper front disc brakes, and jeep grand cherokee rear disc brakes.
1967Barracuda
11-19-2009, 08:20 AM
More Pictures:
6'9"Witha69
11-19-2009, 08:23 AM
Holy rusted metal Batman!! Looks like a lot of fun time in the garage to come. Good luck and thanks for all the pics!
1967Barracuda
11-19-2009, 08:26 AM
Test Fitting The 8 1/4:
NOT A TA
11-19-2009, 08:30 AM
Nice progress! Always liked those fastbacks.
speedfreak68
11-19-2009, 09:59 AM
Do you think that 8/1/4 will hold up to that? You might want to keep your eyes open for a 8 3/4. Sweet project though, I have always wanted one of those!!
Krazed
11-19-2009, 11:40 AM
I like where you're going with this! Id go for an 8.75" rear though, unless you put in a new center section thats built a bit beefier.
1967Barracuda
11-19-2009, 06:42 PM
About the rear, Im planning on rebuilding it and upgrading it with an LPW rear end cover that supports the main caps, upgrading the front yoke to accept the 7290 yoke and installing a positraction center and a ring and pinion that can handle some horse power. If it brakes oh well then i'll get a bigger rear end either 8 3/4 or Dana 60... as far as rear brakes go, i do have a set of 11" x 2.5" rear drums but im now thinking about installing a set of rear discs brakes from a 1993 through 1998 jeep grand cherokee. These jeeps have 8 1/4 rear ends with 5 x 4.5" bolt pattern, so the rear discs are a bolt on deal with parts availible over the counter.
:smoke:
bonecrrusher
11-22-2009, 10:56 AM
What did you use to strip the paint? It looks like whatever you used it did an excellent job....
hivewax
11-22-2009, 04:05 PM
a lot of love, blood, sweat, and tears is going into that car. cool.
1967Barracuda
11-23-2009, 05:45 PM
Lol Thanks i am working hard on this project Im 17 and i bought this car a couple months ago as i always wanted to have a project car, i had to deliver a lot of pizza to afford this barracuda. Any way i used tal-strip chemical stripper then i sanded the remaining paint off with a lite grit sanding disc on an electric drill
1967Barracuda
11-23-2009, 05:48 PM
here is pictures of an 8 1/4 with disc brakes off of a jeep cherokee and another 8 1/4 with the rear end cover im planning on using. right now i cant afford these parts lol so im still brainstorming
1968CamaroSS_Sam
11-23-2009, 05:58 PM
Really nice looking project. Great job.
wellis77
11-24-2009, 05:17 AM
Where are you located? I've got an 8 1/4 and an 8 3/4 (not an a-body, but cheap) I'm getting rid of. I'm in Grand Rapids, MI.
FoxGranadaChuck
11-24-2009, 08:30 AM
I would seriously reconsider the T-56 6-speed install. To my knowledge, that swap would entail a LOT of torsion bar crossmember work to get it to fit! Instead, I would get something along the lines of a Keisler/Tremec 5-speed. This would be almost a direct bolt-in kit (except for welding in the area for the shifter, which you would have to do anyway).
I definitely like your concept, though!!!
FoxGranadaChuck
11-24-2009, 08:40 AM
A sage bit of advice from someone who has been around the block a few times in his life, especially as it relates to planning and building cars. Don't let your ideas become so vast that they don't work. Keep everything as simple (and as inexpensive) as is humanly possible.
From personal experience, I once had a project when I was your age. The problem was that my ideas were so vast that I ignored the simpler issues that had to be addressed. In the end, the floorpan was completely rusted out.
I really like the idea of swapping in the disc brake rear-end. If you are going to do some serious driving, I would do something with the c-clip retainers though.
1967Barracuda
12-08-2009, 05:44 AM
Thank you all here is a little updates, I painted the rear end and stripped the passenger side wheel tub. Right now im working on stripping the underbody after that i'll start on buying new rear suspension parts so i can install the rear. coming along slow and steady! :smoke:
CruizinKev
12-08-2009, 09:07 AM
looks good :twothumbs keep it up!
We painted a Cuda last summer looked just like your. Same color and all. The customer choose to paint it viper orange. It looks great. a great color choice for that car.You can see it on our facebook page. Heres the link
http://www.facebook.com/#/pages/Paradise-Road-Rod-Custom/163984078876?ref=ts
1967Barracuda
12-08-2009, 06:46 PM
I like orange lol and it does look great. My barber school instructor said he would paint it orange too. about the colors im thinking either plum crazy, pearl white, or orange, maybe green metallic
1967Barracuda
12-08-2009, 07:06 PM
that was a great job on the barracuda you did, PRRC, as far as stripping the steel goes I spread the paint stripper on then heat it up and then scrape most of the paint off, then i use a wire wheel and strip it to metal this is my technique if anyone knows a better way please let me know. thanks
Thanks. The customer is putting the car back together himself. We hope the paint survives with out to much damage...LOL
The best way to use stripper is coat the panel and then lay plastic wrap over it to keep the fumes in and working on the paint. It works miracles
autoxcuda
12-18-2009, 11:19 PM
Sounds like a smart and effective plan.
What T-bars, sway bars, and shocks??
The 8 1/4 should be fine behind at 425hp or below 360. And it's lighter than the 8 3/4 !!
autoxcuda
12-18-2009, 11:30 PM
I agree. Keep it simple.
The stuff you laid out is expensive. You can lots of fun with your car without all those trick parts.
My car handles pretty decent without all those trick expensive parts. I built my car while I was in college and drove it daily (still do). While in college I went to autocrosses on weekends when I wasn't loaded down with too much homework.
FoxGranadaChuck
12-19-2009, 12:39 AM
I would seriously re-think this. Why? Because Vipers (for the possible exception of the earliest models) have six-lug wheels. Also, while the Grand Cherokee has five-lug wheels, I am not sure that the wheel-circle diameter is the regular Mopar/Ford 5 X 4 1/2 pattern. Viper calipers are an excellent idea, though. Rick Ehrenburg at Mopar Action magazine used Viper calipers on his Green Brick Valiant with great success.
FoxGranadaChuck
12-19-2009, 12:43 AM
Also, he really doesn't need the '73-76 A-Body K-member. Unless the OE unit is really rusted out, it should hold up well. He would just need some Schumacher conversion mounts to mount a SB V-8 to a 6-cylinder K-member. If he is going to auto-cross it frequently, I would send it to Firm Feel to get them to reinforce it.
autoxcuda
12-19-2009, 01:03 AM
I think he was talking about the www.arengineering.com (http://www.arengineering.com) Viper calipers conversion. They use a Viper/Brembo caliper on a stock spindle with stock 11.75 disk or custom hub and 13" disks. Not Viper hubs or spindles.
ARengineering is the ones you made the Viper conversion that Rick used on his Valiant.
autoxcuda
12-19-2009, 01:17 AM
You are right, it is not 100% needed. But if you are going to go with the other expensive upgrades, I'd upgrade that core feature.
The are some advantages to the '73-76 A-Body K-member. One is the sway bar attachment. The sway bar goes through the K-member and it's narrower allowing for larger backspace rims. The 67-72 style sway bar attachment needs special brackets to hang on the front of the K-member and they sit low and out front. I used to run one and it would meet concrete parking stops before my tires would. Also the 73-76 comes with stock spool type motor mounts. And IMHO, the steering box is natually more reinforced that the 67-72 style K-member (which can be reinforced of course).
You can reinforce the 73-76 even more by welding up the seams and adding steel plates.
Hotchkis now sells lower control arm tabs for narrow sway bar A and E/B-bodies for $29.95/pr.
Here are some pics of my home brewed K-member and LCA reinforcment.
Don't put plates over top of the motor mount support like shown in this cardboard mockup. The motor mount needs that area to move around in. I learned that quickly.
Reforced on left, stock on right.
The LCA pin in the middle with the egg shaped shoulder can not be used with poly LCA bushings. Pins and bores are polished to minimize squeeking and suspension binding.
73-76 sway bar LCA on left and gusseted with 1" strap to be lightweight and effective. 67-72 sway bar style LCA on right.
1967Barracuda
12-20-2009, 02:40 AM
Auto x cuda glad you chimed in, your k memeber looks great.
the jeep cherokee rear discs are 5 on 4.5 and they are a bolt on deal ( jeep cherokkes used 8 1/4 rear end) Im not planning on building this car in 4 months lol. might take me a couple of years but ill get it nice & slowly. I'll post some updated pictures. My local junkyard is full of dodge darts mostly late 1970's. And a lot of oter mopars too & prices are decent.
1967Barracuda
12-21-2009, 08:27 PM
auto x cuda you seem to understand the barracuda lol. im planning on 17" wheels all around. I dont knwo what width to go id like to run 275 40 17 on the front, and a little wider in the rear maybe 295 40 17. my car has the leaf springs in stock location and im going to go with the 1973+ k member with sway bar and discs i dont mind if the tires stick out.
1967Barracuda
12-21-2009, 08:28 PM
Engine plans changed lol... got a hold a 440 out of a police car will post pics asap!
autoxcuda
12-21-2009, 11:41 PM
You can run 275/40/17 in front AND rear. That way you can rotate tires if you go to a track. That is a very nice feature. With a street or aggressive street alignment you will wear the outer edges of the front tires on a road course or with a lot of autocross runs. With stock hubs run 17x9 rims 5.5" backspacing. You will need to fold back 1" by 3" section of the front fender lip.
I just folded back my fender lips last weekend. I have pictures. I went a little too agressive with a 2" fold back.
You can't really have the tires sticking out or the tire will rub, chunk, and cut on the fender top.
You can run the 275/40/17 in the rear with 5.5" backspacing but you will need a rear end 2" wider than the stock A-body 8 3/4 rear. That is actually will save you some money, because that calculates out to a 65-67 B-Body or a 68-70 B-body. Check a width chart online.
A 65-67 B-Body 8 3/4 rear end is about $250-350 used WITH big bolt pattern and a 742 case center section open rear highway gears. A 66-72 A-Body 8 3/4 rear end is about 400-500 used WITHOUT big bolt pattern and a 742 or 489 case center section open rear highway gears. THEN you have to buy large bolt pattern axles for it for an additional $250+ or so with bearings. See where I'm going with this??
Now to use the 65-67 B-Body 8 3/4 rear end, you'll have to relocated the spring pads. I'd wild guess $100 at a rear end place.
Must read this about fitting 17" rims on an A-body by Clair Davis: http://www.moparfins.com/CLAIRDAVIS/Cobra_Wheel.htm
Just pointing out an alternative. I know you have a 8 1/4 in your hand now. Not a bad choice, IHMO. But you will have to run a 275/40/17 on a 17x9 with 4.5" backspacing
I don't think a 295 40 17 is going to fit even if you fold over the rear fender lip on topwith lowered suspension and stock frame rail location. Careful, some of the drag type guys will probably say they fit a 295/50/15 or something back there. BUT they have the rear end all jacked up drag style.
Are you on www.forabodiesonly.com (http://www.forabodiesonly.com) ?? There are some good threads there on this subject.
autoxcuda
12-21-2009, 11:50 PM
I would not do that.
-Engine is heavy
-You will need schumacher conversion motor mounts
-You will be stuck with expensive TTI headers if you want any form of ground clearance
Trade that motor and some cash for a 360.
FoxGranadaChuck
12-22-2009, 06:24 AM
A 65-67 B-Body 8 3/4 rear end is about $250-350 used WITH big bolt pattern and a 742 case center section open rear highway gears. A 66-72 A-Body 8 3/4 rear end is about 400-500 used WITH big bolt pattern and a 742 or 489 case center section open rear highway gears. THEN you have to buy large bolt pattern axles for it for an additional $250+ or so with bearings. See where I'm going with this??
Excellent advice. Keep things some resemblance of simple.
FoxGranadaChuck
12-22-2009, 06:26 AM
-Engine is heavy
Neither would I. The 440 IS excessively heavy for the kind of driving that you intend to do with your 'Cuda. I would drop in a nice Magnum 360 motor.
1967Barracuda
12-28-2009, 05:35 PM
im almost finished stripping the rear section of the underbody and im close to finishing the welding in the trunk. got some parts painted. project is rollin! close to getting the car back on all four, i will be looking forward to a clean garage also.
pics are old have some more will post other pics soon! Auto x cuda, how does 17 x 9.5" with 4.50 back space for the rear and front sound. american racing sells this rim with 5.5" backspace aswell but i love the deep dish look. http://www.summitracing.com/search/Brand/American-Racing/Product-Line/American-Racing-Torq-Thrust-II-Wheels/Part-Type/Wheels/Wheel-Width-in/9-50-in/Wheel-Diameter/17-in/Wheel-Bolt-Pattern/5-x-4-1-2-in/?Ns=Rank%7cAsc&autoview=SKU
autoxcuda
12-28-2009, 08:36 PM
If you run 17 x 9.5" with 4.50 backspacing they will NOT fit in the front. You will have to add an 1" flare out around the fender.
Those 17 x 9.5" with 4.50 backspacing rims and tires will fit the rear of a Barracuda with stock A-body width rear end. If anything might need to roll the upper wheel lip.
You can run the 4.5 backspace in the rear and run the 5.5 backspacing in the front. That would give your a deep look in the rear.
You know even a 17 x 9.5" with 5.50 still has 4" on the frontside of the rim. That is more than the very common 15x7 with 4" backspace (3" frontside) or a 15x8 with 4.5" backspace (3.5" frontside).
There's lots of cars with 15x7 and 15x8 torque thrusts to compare to. There's not a good picture of a 17x9.5 with 5.5 backspacing on the Summit site.
EL RAFA_D
12-29-2009, 08:09 AM
that spectacular car! very good project!
have plenty of work ahead
good luck with that!
1967Barracuda
01-24-2010, 07:02 PM
I got the underside done for the most part, now im working on getting the car back together all that stripping work is over for now :enguard: It was a pain! :bsjerk: :smoke:
Firm feel road race leaf springs will be installed shortly so i can get the car back on 4 wheels then roll it out and tow it to my fathers garage. i used 3m undercoating then sprayed gloss black over top to seal it up. Some spots need touch up here and there, ill finish the rest of the under body restoration as the project moves along. The color is plum crazy!
CruizinKev
01-24-2010, 09:07 PM
:twothumbs
1967Barracuda
01-27-2010, 07:12 PM
back on all 4!
1967Barracuda
02-17-2010, 12:37 PM
I installed the headliner (Its wrinkle free now that i used the heat gun and installed the sunvisors and rear view mirrior) I also installed both doors tail lights and dash. The next thing on the list to intall is the rear windshield then the rear quarter windows, Starting to get some steady progress :smoke:
Treated the rust cleaned it and brush it flat black (the underneath of the dash) when it gets warm im going to spray the front part of the dash semi gloss.
This was when i was fooling with colors i finally decided on PlUm cRaZy :1st:
monteboy84
02-17-2010, 01:12 PM
I really hope this doesn't come off harsh, I know you're excited, but I think you're getting a little ahead of yourself by working on reassembly. When do you plan to repair the rust on the quarters?
Honestly, I'm really trying to give you some good advice here, I know your budget is tight (everyone's is) but you'll be far money ahead if you focus on one area at a time and work through your list of things to do. Now that you have the car in primer, you're going to need to remove the primer and re-prime when you fix the rusty areas.
I hope you take this to heart, I know what it's like to be a young kid and excited about a project, but going about it methodically will save you a pile of cash and headache in the end....
FoxGranadaChuck
02-17-2010, 02:36 PM
+1 in agreement
Johnny C.
02-18-2010, 06:25 PM
Looking good so far. Cool project.
1967Barracuda
02-19-2010, 06:52 PM
Lol Im not looking to spend 150 Thousand on this project but thanks for the advice and the good comment johhny c. I'm looking forward to finishing the trunk tomorrow :smoke:
1967Barracuda
02-25-2010, 04:14 PM
I reupholstered the back seat with the original vinyl after welding a new frame for the back seat.
Done! :1st: :smoke:
I picked this dash pad up at the junkyard for 10 bucks! it came off of a 1975 plymouth scamp and it fits on my 1967 rally dash perfect I just need to re die it black it doesnt have any tears or crazcks! :yum:
FoxGranadaChuck
02-25-2010, 04:42 PM
Sweet-looking project so far!!
Dalamar
02-26-2010, 08:10 AM
nice progress!
1967Barracuda
03-03-2010, 03:49 PM
completley stripped the underside of both fenders and painted semi gloss black, tore the engine out and stripped the front clip and primered. I installed the driver side fender for the last time and really sealed it up good. Next thing on the list is to finish the sheetmetal work on the firewall then install the Dash and everything that goes underneath it. Gunna take a break for now though!
1967Barracuda
05-17-2010, 10:23 AM
been a while havent really been taking pictures here are some updates
http://www.showcars-bodyparts.com/barracud.html
Motown 454
05-17-2010, 04:35 PM
Nice progress it looks good.
FoxGranadaChuck
05-18-2010, 12:21 PM
Looking great!! I thought that it was time again to bash your project. LOL
1967Barracuda
01-30-2012, 12:08 PM
I haven't been on the site for a while however, I'm returning back.
A few things I have progressed on are that I finished fabricating the seat brackets inorder to mount the Summit Sport seats. They came out great, All features of the summit sport seats work as they are suppose to. They recline/decline as they should and the sliding tracks to adjust seat position work aswell. I was worried about this with the customized seat brackets I came up with but, I'm happy with the results. I used two sets of bench seat mounts from a 1970 chrysler (C- Body), Shaved them smooth and then mounted the sport seats to them mounts via Grade 8 Hardware. Also would like to add that with the C-Body bench seat tracks floor panel modding was unnecessary, minus drilling mounting holes.
I have removed the entire front suspension in order to swap it out for an RMS AlterKtion this summer
I finished the headliner installation it came out great, very happy.
Mounted my ididit steering column,
Im going to start working back on the car this summer, I'm starting the summer project with welding rotted sheet metal on the floor (major) & engine compartment (very minor). Then my next part of the plan is to install the AlterKtion Front end and will take the project from there.
1967Barracuda
01-30-2012, 12:13 PM
1967Barracuda
01-30-2012, 12:16 PM
Dolmaner
01-30-2012, 05:42 PM
awesome car keep the updates comin
Rols574
01-30-2012, 06:41 PM
just my opinion, but those seats are too high. they almost touch the roof. Can you chop some inches off?
1967Barracuda
01-31-2012, 10:20 AM
Yes, It would require cutting the mounting brackets heigth down 1 inch or so. I do agree on the height of the seats the only flaw is that they tap the sunvisors in their current moment. Lowering them is the only thing they need.
I wanted to wait until I finished the floor pan work along with the transmission tunnel work and have the carpet & transmission in the car with the steering wheel in aswell before i took the seats anyfurther than lining them up evenly in conjuction with the steering column, side arm rests and width between each seat at the current state of the project. In order for the entire package to fit like it should I'd like to have the seats, shifter position, steering wheel, pedals, armrests, & seat belts and all this into play before finalizing.
1967Barracuda
01-31-2012, 10:36 AM
Also I have My bellhousing (quicktime RM 8073),a Victor 440 intake manifold (edel 2954), 2 inch primary with 3.5 inch collectors CPPA Abody 440 headers. I'm going to be attempting at a edlebrock performer rpm head 450 - 475hp, stock crank 440. I have a 1978 cast 440 for the build.
Im going to mount the engine with a motor/mid plate and a cross member for the transmission attaching to the sub frame connectors
(old pic of eng. compartment, back to primer now. will be body color once motor/midplate work is done)
polished off with steel wool, going to go with header wrap-
The trunk divider and wheel well covers are in-
1967Barracuda
01-31-2012, 11:12 AM
Going to go with a Mopar limited slip differential for 27 spline 8.25. Availible on summit if I cant find a used one in good condition. I would also like to change the gear ratio to 3.73 or so. besides that I finally need to mount a floor-mount style emergency brake handle and run the ebrake cables to the rea rotors. I have the emergency brake cable brackets.
New pads and rotors and rebuilt the emergency brake drum on each side of the rear.
Stainless steel brake lines hand fabricated need new pressure lines for the caliper in order to finish the brake line installation-
