View Full Version : Stock Frame Idea
upacreek
04-12-2005, 06:14 AM
Ok dont flame me but I was wondering if it would be possible to cut out the center support on the front sub frame where the engine mount and where the basic suspension and build a kmember like they do on fox body mustangs?
JLM
04-12-2005, 06:39 AM
You mean as in a tubular piece? It would certainly cut down on some of the front end weight. If it was engineered right I wouldn't see why this wouldn't be a good thing.
79T/Aman
04-12-2005, 04:25 PM
that would not be stiff enough, too many bolted pieces, if it was a unibody that would be ok.
oleyeller
04-12-2005, 05:39 PM
Check out the turbo 69 that was built at Gale Banks shop.
They set the engine back and made a removable center cross member that could be removed to change the pan or inspect bearings and such. The entire car is quite a piece of engineering. But yea, you can cut up anything. http://www.bankspower.com/camaro-Framework.cfm
04-12-2005, 10:10 PM
you beat me to it. https://static1.pt-content.com/images/noimg.gif
