Results 1 to 10 of 10
11-16-2009 #1
Leaf spring clip nuts I have a better solution. Good for other suspensions too.
Ive already made these for my car just need to install.
Many talks about the clip nuts for the front leaf mounts have come up in the years Ive been on this and other sites But ive never seen a solution other than another type of clip nut. Well here is my solution.
First make a plug out of 1 inch round stock drill and tap one end 1/2 13 then on the car from under drill a marker hole through to the interior floor. then using that hole as a guide drill a 1 inch or slightly smaller hole through floor only not the frame then take the plug put it through till it seats on the inner frame. run a bolt in tight and weld the plug in... What do you think... This in my mind will be 100% stronger than clip nuts plus larger bolt and solid mounted to frame top n bottom Also suspension systems like the Quadralink Prodigy bar air bar g-bar glink and anyone else that uses the front spring cup could use this idea..... opinions please...
