View Full Version : tig welding stainless to mild steel
scotzilla
11-15-2009, 07:02 AM
i want to tig weld the trim to the body on my continental- A buddy of mine is telling me its going to crack but ive done it before. I just used stainless filler rod and it was fine. Is it going to crack down the road? We did it at a shop I worked at a few years back but i havent seen the car since to check on it
parsonsj
11-15-2009, 10:37 AM
It will be fine, assuming good welding technique.
jp
John Wright
11-16-2009, 04:51 AM
The stainless filler should have enough nickle in it to help the weld stay fairly ductile.
toxicz28
11-17-2009, 02:05 PM
Use 309L wire. Best for dissimilar metals.
scotzilla
12-28-2009, 12:28 PM
thanks- ill try it out and report back
ironhide
01-25-2010, 06:23 PM
I would use some silicon bronze rod . Much lower heat .And when welding stainless and mild I'm pretty sure you use mild rod . The mild will pick up the nickel .
toxicz28
01-28-2010, 04:43 PM
And when welding stainless and mild I'm pretty sure you use mild rod.
No, 309L is what you need to use. :cheers:
tankhunter
02-21-2010, 07:28 AM
it will be fine
