View Full Version : Powerstearing problem
Roadrage David
11-14-2009, 08:10 AM
Mij DSE powerstearing system conected to the hydra boost
is making whinig noises afther 4000 miles not pnly when turning the strearing wheel bt also drivig on the highway also when i chekt my remote powerstearing oil canuister the oil was bubbling!!. anybody knows what the problem is ???..........
Roadrage David
11-15-2009, 04:18 AM
Ok did some cheking and my oil is waisted afther only 3600miles i used a green powersteering oil , its brouwn red now!!! so i gues having the hydra boost system conected to the powersteering system wil heavely efect the durabilety of the oil..
Roadbuster
11-15-2009, 10:15 AM
Are you running a P/S cooler? My hydroboost gets pretty warm even with the cooler I have and that could be an issue.
BTW Thanks for the heads up, I will be adding a P/S fluid check to my winter maintenance list. I use Redline synthetic P/S fluid.
Jon
Roadrage David
11-16-2009, 03:47 AM
Hhahaha yes i run the DSE powerstearing cooler , but im going to use a oil cooler like the ones in use to cool my transmission
