View Full Version : New here... swapping a LS2 into my FC
Andrew R
11-11-2009, 03:21 PM
Hey all!
Stumbled onto this forum and noticed a few people from other forums I regular are on here.
Anyway...
87 rx-7 here is the short list:
LS2
T-101 4 speed dogbox
Engine is a longblock so I need all the F-body accessories/brackets
Turn One PS pump
ATI crank pully
Bunch of ARP/Katech bolts
LS6 intake manifold, injectors, TB
F Body ECU and Harness I have HP Tuners
8pt cage (built by me https://static1.pt-content.com/images/noimg.gif )
3qt accusump with manual valve
Canton remote Oil filter
Oil cooler
PS cooler
F-Body Pan/tray
Improved racing baffle
Melling High pressure oil pump
Sumped Fuel tank
Walboro 255 inline pump
Aeromotive filter
Aeromotive FPR
-8 Stainless lines to -6 return (everything done is SS lines)
Aeromotive fuel rails
JTR 1-7/8 Longtubes
3" straight out the rear (no mufflers)
RPS twin friction clutch and RPS custom FW 32lbs combined weight
Wilwood 7/8 MC with adaptor
Big radiator and be-cool 2600cfm fan
I have most of that crap waiting to go in.
here she is:
https://static1.pt-content.com/images/pt/2009/11/3956634879_ab6fb72fe2_b-1.jpg
Getting a LS2 put in during this off season, chassis is just about prepped for the swap:
https://static1.pt-content.com/images/pt/2009/11/4073733014_17ed6b25a4-1.jpg
going with a Tex Racing T-101 dogbox
https://static1.pt-content.com/images/pt/2009/11/4078689349_8bdc708a53_m-1.jpg
Interior is out getting ready for the cage:
https://static1.pt-content.com/images/pt/2009/11/4072973251_03b6493b25-1.jpg
I know some people don't consider drifting a legitimate motorsport -but it is... and it's fun!
https://static1.pt-content.com/images/pt/2009/11/4082544681_df879b0dd6_o-1.jpg
Supra510
11-11-2009, 03:25 PM
Cool project. What flares are those?
Andrew R
11-11-2009, 03:26 PM
ZG flares that I modified to fit :)
Mr.VENGEANCE
11-11-2009, 04:35 PM
hahaha!
another RX7 owner.. mines an FD tho..
and yours is streetfighter at that.. so i like it off the bat.
1971CHEVELLE
11-11-2009, 05:34 PM
welcome to the site
Andrew R
11-21-2009, 01:04 PM
I had the gear ratios worked and a fresh rebuilt from a former Team Penske member so all is in good order.
Trans came in today:
https://static1.pt-content.com/images/pt/2009/11/4117735526_a493f13754-1.jpg
here it is after an hour of cleaning and some engine enamel:
https://static1.pt-content.com/images/pt/2009/11/4118019397_b929cb3714-1.jpg
only what... 4 months till I get to use it :(
Here are a few more pics:
https://static1.pt-content.com/images/pt/2009/11/4118788156_5cb1846d1b-1.jpg
one for scale:
https://static1.pt-content.com/images/pt/2009/11/4118019159_cda71f9bda-1.jpg
Here are the gear ratios:
https://static1.pt-content.com/images/pt/2009/11/4052641743_02c6fb83b8_o-1.jpg
1st is actually 2.26 and second is 1.52
I realize 1st gear is long -but this is not a "out of the hole" car and fig I'll have 400+ rwhp/rwtq
srh3trinity
11-21-2009, 03:34 PM
I have always liked the FC body style, I would love to have one with an LS2.
Andrew R
11-21-2009, 04:59 PM
The swap is cake... do it! check out www.v8rx7forum.com there are quite a few good deals on LS1/T56 FC rightnow
steelcity6
11-21-2009, 08:17 PM
I was considering that swap for a while. I run a lexus SC now but wanted something smaller so I found an 800 dollar e36...then we did a 6.0 swap it is almost together. I f you need any advice pm me. I may be able to help.
Andrew R
11-22-2009, 01:57 AM
nice swap!
steelcity6
11-22-2009, 10:44 AM
Yeah , it wasnt as hard as I thought it would be. truth be told the only cutting on the car was for the shfter.and that was bout a 2"x 1" piece. i GrannySpeed makes a kit now for the rx-7. Had to have custom headers made. other than that very cool swap. I also have a guy in my car club that does have an ls2 swapped fd . just hit Pittspeed.com and do a search there is a build thread. if you need any help.
Andrew R
12-04-2009, 09:33 AM
So after a bit of research I decided to go with a quartermaster bellhousing and TOB:
ordered them today ;)
FYI guys that are sick of GM's crappy TOB can go with the QM unit above.
Got mine for just under $200
steelcity6
12-04-2009, 10:33 AM
Very nice, I picked up a fast 92 intake for mine and a big tb..I see you are in NJ not to far we have a tuner from VA speed in april if you need any tuning help ..guy is amazing
Andrew R
01-18-2010, 04:03 AM
some small progress:
https://static1.pt-content.com/images/pt/2010/01/4283612168_21e13dcc70-1.jpg
This finally showed up:
https://static1.pt-content.com/images/pt/2010/01/4192877525_b5c3a4b5b7-1.jpg
lots of cleaning and stuff:
https://static1.pt-content.com/images/pt/2010/01/4238230022_f82b355f79_b-1.jpg
https://static1.pt-content.com/images/pt/2010/01/4251133064_d2598593d6-1.jpg
trimmed down the wiring harness to the basics:
https://static1.pt-content.com/images/pt/2010/01/4255584536_caece53665-1.jpg
https://static1.pt-content.com/images/pt/2010/01/4256584583_db4eb29465-1.jpg
got some loom from wirecare:
https://static1.pt-content.com/images/pt/2010/01/4267767558_2bfb83dfe5-1.jpg
going to knock out the cage next weekend.
The Stickman
01-18-2010, 11:41 AM
Welcome to the forum. You might want to move mos of this to the project updates section.
ponchopwr70
01-18-2010, 01:37 PM
Welcome and sweet car!
CruizinKev
01-19-2010, 07:53 AM
sweet! nice progress :twothumbs
Dalamar
01-20-2010, 09:29 AM
Awsome build you have going there! looks to be a very fun car when you're done.
killer67
01-27-2010, 12:01 AM
looks like you made some forward movement - nice motor
Andrew R
01-28-2010, 04:11 AM
put everything together for a moch up
https://static1.pt-content.com/images/pt/2010/01/4309691493_51099010ae-1.jpg
PT_79_TA_461
02-03-2010, 11:14 AM
some call it drifting....i call it power sliding....same thing.....nice build....i love the bellhousing.
Andrew R
02-28-2010, 06:56 AM
have not updated over here in a while:
prepped everything for the test fit lastnight -just waiting on the bellhousing.
https://static1.pt-content.com/images/pt/2010/02/4384924428_571ddbb03e-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4384924618_a35d4d0697-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4384924770_9619163f7b-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4388287319_6e429149d0-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4388288649_2395eab7e8-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4388288983_eb83dbd19a-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4388287631_52986965f8_b-1.jpg
some more goodies:
https://static1.pt-content.com/images/pt/2010/02/4353784353_38c5dac077-1.jpg
Flex-a-lite 2500cfm 16.5" fan
https://static1.pt-content.com/images/pt/2010/02/4353784631_aff1619541-1.jpg
https://static1.pt-content.com/images/pt/2010/02/4353784953_00bcfc80ed-1.jpg
Once the engine is in place I'll do all the shrouds ect... both the fan and rad are very nice!
Also got a bunch of ARP fasteners.... FW,WP, Balancer and some other stuff...
1968CamaroSS_Sam
03-02-2010, 06:19 PM
Pretty cool project you have there. Welcome to the site.
