View Full Version : smooth firewall and bondo
astross89
11-08-2009, 08:39 PM
I'm smoothing out my firewall on my 68 camaro. My question is if I use bondo instead of all metel, will I have a problem with heat?
67 ls1 vert
11-08-2009, 08:49 PM
not with heat but it will crack.
XLexusTech
11-09-2009, 06:51 PM
is all metal the way to go?
The WidowMaker
11-09-2009, 07:40 PM
are you welding in a flat sheet and using the filler (dont use bondo) to smooth the transition, or are you just slapping some filler on the entire firewall to smooth it? that will make a big difference.
Tim
astross89
11-09-2009, 09:08 PM
I welded a flat pieace of sheet metal welded solid all around. Just trying to smooth out the and small waves in it
67 ls1 vert
11-09-2009, 09:17 PM
You might be okay if all you are doing is smoothing out the waves. Just dont want to use it to fill in the whole firewall as it crack under the stress.
