View Full Version : 0-200-0
jeff s
04-09-2005, 08:29 PM
A new contest at Silver State next month. Anyone know of any cars participating in this besides Big Red?
I've been approached by some sponsors that want my Ultima run it. I can spray it or try to build a twin turbo in 4 weeks. Any thoughts? Should I do it?
gchandler
04-09-2005, 08:58 PM
The ultima would be a hard one to beat. Solid power to weight ratio. I remember seeing a video of an ulitima doing a 0 100 0 blast somewhere on the net and it was increadibly fast. I believe it was running a 377 smallblock.
Blown353
04-09-2005, 09:37 PM
Could you throw a Magnacharger on it in quick order? May get you there, and take less time/effort than a turbo setup since time is of the essence. Run their air/water intercooler and throw some ice in the sucker.
You've definately got a weight advantage and I'm also guessing a Cd advantage, which will help in both areas of the test.
Troy
Martin71RS
04-09-2005, 11:23 PM
Jeff, even without the extra power I think you have a good chance....the low weight of the Ultima will make it accellerate and brake fast.....but extra power wouldn't hurt...
zbugger
04-09-2005, 11:55 PM
Am I wrong or don't you already have a traction problem in that car? And it is damn quick with that too. I say run it as is. But, yeah, that magnacharger idea is a damn good one. And the twin turbo idea is even more insane. Ok, I think I wanna see that. Think you can pull that off in time? If you can...... :hail:
ProdigyCustoms
04-10-2005, 03:09 AM
In all honesty, for your purpose, I would spray it. You only need the horsepower for 10 to 15 seconds. Assuming you have normal forged pistons, with some race gas, you could squeeze 300HP on it, maybe even 400HP with a progressive only peaking for a few seconds. You can easily control the HP with a progressive timer and window switch to bring it on as the car stays hooked. It could be as simple as a 2 stage Twin Gemini plate that would allow you to use one stage through the gears and bring the second stage on in high gear when you are well hooked and have 2 hands on the wheel. And you could install the entire system, plates, bottles, electronics, in 2 days.
I would highly suggest using John Phillips at NX for Da juice. With little T and T time, you need real support.
It seems inconcievable to do a TT motor in 4 weeks that is built, installed, plumbed and tested. Also cost for NOS (not noose) would be much less then any forced induction set up.
Now would the car be cooler with a TT? hell yeah!
Jeff - I say GO FOR IT - and I am by no means an expert, but Frank's idea makes the most sense to me. just my useless 2 cents.....
MoeBawlz
04-10-2005, 10:49 AM
go for it... I just saw a red Ultima down here in Bloomintgon Normal at a car show and I talked to the guy, He one of the guys from Ultima I guess and I asked if he knew you(jeff s) and he said he spent the morning talking to you. Its a small world afterall...
I sat in the car, man that thing is TIGHT!!! but really cool... and i mean REALLY cool... anyway he made a comment about doing a 0-100-0 and it being faster than the supercars on the market. I then asked what motor was in that compairison car and he said it was a 600hp small block.
I think you should go for it and spray the motor, now will spraying for that lenght of time do any damage? Ive heard people say dont spray any more than like 10-15 seconds. Kinda as a rule of thumb. I dont know of any truth to that as im no nitrous guru or anything. But would it be a good idea to also run a nitrous controller like a nitrous mastermind or something?
ProdigyCustoms
04-10-2005, 02:05 PM
[QUOTE=MoeBawlz]
I think you should go for it and spray the motor, now will spraying for that lenght of time do any damage? Ive heard people say dont spray any more than like 10-15 seconds. QUOTE]
Na, it wont be more then 15 seconds anyway. And the window switch would allow it to come on and off as he runs through the gears, then spray it big for a few seconds in high gear.
jeff s
04-10-2005, 07:23 PM
The red Ultima in Bloomington is great guy named Ed Ingalls, he used to be a rep for Ultima in the USA. They (Ultima Sports UK) have pi***d off every one they've worked with here in the USA. We met on HR Power Tour in 2001 when he picked me and my son up along side the road after my Caddy puked in AZ.
I have stock pistons in my LS6, which worries me. I installed a single fogger wet NOS for Pump gas Drags last year, but didn't get picked. It's wired to the steering wheel buttons. I can adjust to 150hp max or add a second nozzle for 300hp. I'd also have to change 5th gear to a taller ratio as I can only go 196 mph now. I have a couple LS1's with the parts to rebuild one except pistons.
Flyboy
04-10-2005, 07:42 PM
Jeff, I have been working the SSCC races as a timing official since 2003. Or at least I do when i'm not out of the country (like I will be for the May race) or having to work those weekends. Next time you are going to make it back to Ely for the race (obviously not including May), shoot me a PM if you can remember. I love the Ultima's, and would love the opportunity to check one out up close. Owning one is just a pipe dream on a military budget, but I can always daydream. :drool:
Also, I say go for it! Give Big Red a run for its money. Wish I could make it up for the May race. I've heard all about Big Red and would love to see the new 0-200-0 contest. Are they going to run that in conjunction with the High Noon Shootout, or is it taking the place of the High Noon Shootout?
Stu Seitz
04-10-2005, 07:59 PM
Wish you could race Big Red for pinks lol
MarkM66
04-11-2005, 10:17 AM
Sounds like a great idea. DO IT! And good luck!
USAZR1
04-11-2005, 11:02 AM
I agree with you,Jeff. Running a 150 shot with the stock LS6 pistons would be a little shaky. I think a 300 shot with them would be creating a grenade.
Hacker Joe
04-11-2005, 11:23 AM
if you run good gas you should have no problem running at least 200 hp of nitrous on stock pistons. I ran 300 for quite a while before I hurt my LS1 (pinched a ring end gap and broke a piston) and that was on 93 pump gas in 100 degree weather when it got hurt. I actually sprayed over 400 on 100 unleaded race gas in cool weather without a problem.
That was all on a stock long block pushing a 3800 lb camaro in the 10's in 1999
jeff s
04-14-2005, 07:29 PM
I recieved a phone call tonight I'm in the 0-200-0 and the Silver State. I am building a twin turbo LS1, if I don't get it done in time, I'll make due with my NOS. Also may get another Chicago car to go along that'd put Big Red on the trailer for sure. It's gonna be wacky and that's all I'm saying.
www.schwartzperformance.com
SicMonte
04-14-2005, 07:48 PM
awesome man..i just checked out your website...GO FOR IT!!!!!!!!
stealthjr
04-14-2005, 08:46 PM
Hey Jeff,
I'm going to be there running the actual 90 mile race...not the 0-200-0 race. I assume you will be around the car show on Saturday in Ely or teching in Vegas on Thursday. Either way, stop by and say hi! I will be in my 1969 Camaro (blue w/black stripes) the same 1969 Camaro on this month's (June) PHR cover. :icon996:
My name is Robert and I'm an alcoholic...first rounds on me! :Alchy:
See ya!
MarkM66
04-15-2005, 07:41 AM
Wow! Looking forward to hearing the results.
Steve1968LS2
04-15-2005, 08:00 AM
Hey Jeff,
See ya!
you're on the June Cover of PHR??? -- you're such the star.. ;)
If Marc gets sick I call shotgun on the race!!! I'm gonna need the practice..
tireman
04-15-2005, 08:22 AM
You're running a G50 Porsche tranny? Will it take that kind of power?
parsonsj
04-15-2005, 09:19 AM
Jeff,
That sounds incredibly cool. I only wish I could make it out to watch the fun. How does the Ultima behave at those speeds? Not many cars will stay on the ground at those speeds ... if you've gone 196 in the past you've got some idea of what you're getting into.
Make sure somebody on your crew has a video camera, and keep us posted on how it's going.
jp
jeff s
04-15-2005, 04:58 PM
I am running both events as well as car show.
I have beefed up Porsche Turbo Getrag G50/52, ring gear is approx 9".
You'll see it on TV, and there will be a camera in the car.
USAZR1
04-15-2005, 05:24 PM
Jeff,my partner and I were talking today about maybe building a Lola T70 kit and would need one of those Porsche TT G50/52 transmissions.
What's the going rate and how hard is it to source one?
jeff s
04-15-2005, 06:49 PM
Call Roger Brown at Powerhaus II in Colorado, the best source for transaxles.
TitoJones
04-15-2005, 07:16 PM
Any of you in Vegas for Tech, should give the ATS boys( Wickedmotorhead, Chicane, Baz67, and myself) a call for some drinks. PM me for a contact #.
Good luck Jeff, congrats on the new shop, and PHR coverage.
Tyler
Marcus SC&C
04-17-2005, 09:23 AM
I`ll be rootin for ya Jeff. :fingersx: We met you,your son and Ed on the `03 Power Tour and I was very impressed by the engineering of the car. It would be great if both you and Ed could compete. As much as I like BigRed,vs. the Ultima I think it`s toast. Now if I could just talk a customer into letting me do an Ultima for them so I could play with it. ;)Marcus SC&C
