View Full Version : How can I tell a GTO from a Le Mans
socalfandabodys
10-25-2009, 06:12 AM
I ran across a 64 GTO convertible for sale for a very reasonable price. I'm not really a GTO guy so I don't know how to tell if it is a GTO or if it is a cloned Le Mans. This is the vin number 824F27513. The guy says it's a real numbers matching GTO. Thanks for the help
dipren443
10-25-2009, 06:21 AM
If I were in your shoes, I would pay PHS to get the full packet on the car. Worth the $50 in my opinion.
http://www.phs-online.com/order.htm
ragtop70gto
10-25-2009, 06:34 AM
There isn't any way to tell the difference from the VIN on 64-65 or 72-74 models. You can purchase a package from www.phs-online.com (http://www.phs-online.com) that will provide you with the following:
A copy of the factory invoice or billing history
A letter decoding the options (when necessary)
A copy of a dealer order form for that year
Other specific information for that year and model Pontiac, if available
The $50 is worth your peace of mind. Good Luck!
terryr
10-25-2009, 07:00 AM
Musclecar did a series of shows on modding a Lemans and pointed out the differences. I remember taillights, stamped grill in fender.
Bill Howell
10-25-2009, 01:35 PM
http://books.google.com/books?id=4Yu2yAliH8UC&pg=PA124&lpg=PA124&dq=identify+real+64+gto&source=bl&ots=Qc7_NboLWu&sig=GgCjhMGIZuR5whLddBNbS4DTm1M&hl=en&ei=lcPkSpKQD8ug8Abvi6CIBw&sa=X&oi=book_result&ct=result&resnum=2&ved=0CA4Q6AEwAQ#v=onepage&q=identify%20real%2064%20gto&f=false
read last line about 64s. Cowl tag should have "5N" in accessory line. Not guaranteed to be a GTO but has to have that to be one.
Bill Howell
10-25-2009, 01:37 PM
More info found here
http://www.gtoforum.com/f12/unigue-64-thru-74-gto-facts-351/
QUOTE
(1964-65) One way to identify a GTO in these two years is by an accessory code on the data plate or also known as the body tag. 5N code was used to show that the body had went through the conversion needed to convert the Le Mans to GTO. Only two plants used this code though. Pontiac (P, PO, PON) and Kansas City, MO. (K, KC, M, KAN).
CONELRAD
03-31-2013, 09:19 PM
One way is to remove the rear seat and the upholstery on the inside of the rear quarter panels. Look and see if the holes in the quarter panels have been filled where the LeMans "louvers" trim was removed to make it look like a GTO. If it's a really good clone they might have finished the filled louver holes on the inside of the quarter panel - but if it was a quicky clone - you might see the indentations for the "louvers" or the residue of bondo or filler that oozed through when the louvers were filled. On a convertible you might be able to look down past the top mechanism with a flashlight and inspect the inner rear quarter panel without removing the upholstery. Maybe.
Or send the ViN to PHS. But that takes time and assumes that the VIN is not faked.
tripower
03-31-2013, 10:18 PM
Another vote for PHS documentation...I got it before I bought my 65 and it checked out. Good luck.
