View Full Version : Wheel stud advice
130fe
10-17-2009, 06:08 AM
I currently have ATS spindles on front (with 12mm .509 knurl) and moser 12 bolt axles on the rear (7/16 .486 knurl). I am wanting to install longer studs on each and use the same stud pattern (metric or standard). Has anyone else done this? I have looked at Summit and Jegs but am just looking for some advice on what others have done.
bmx1112
10-20-2009, 03:47 PM
i have changed out my rear studs with longer ones that are metric 12mmx1.5 ARP 100-7712 made for 1980-2000 Honda and have a .485 knurl my axles are also moser are you sure your knurl diameter is correct or did you drill the axles already to put in the 7/16 studs?
130fe
10-20-2009, 06:35 PM
Thanks for the reply, I guessed I typed the wrong knurl number from moser. They say they use a .480 knurl in their axles. Anyone else have any inputs?
