View Full Version : Widest possible wheel/tire on '68 Camaro???
BuddyP
04-07-2005, 05:47 PM
What is the widest wheel/tire you can use on the rear of a '68 Camaro with stock rear wheel wells?
shanekennedy
04-08-2005, 12:47 PM
275/40/17ish
fast
04-11-2005, 03:56 AM
first post, hehe
have seen 9.5 and 10s on rear, 5.5 and 5.75" bs
personally thinking 285/40 rears around 26" tall, good height
67kato
04-11-2005, 06:03 AM
Hey Fast:
Does anyone have that setup with pics that could be seen?
colt zantop
04-11-2005, 04:28 PM
im running 275/35/18s with 9.5 wheels with 5.5 bs and no problems rubbing at all. I also have rear disc brakes....
Hammered
04-11-2005, 06:29 PM
Colt,
Did you have to roll the fender lips? Also, do you have discs or factory drums?
John
colt zantop
04-11-2005, 06:43 PM
I have baer discs on all 4 corners, and no, I didnt touch the fender lip at all. now for a 10'' rim.......you might need to do some mods......but 9.5 with 5.5 bs fit no problem.some cars may vary so measure 100 times before ordering.... :)
Tom Nickols
04-12-2005, 11:59 AM
I have just fitted 275/40/17 on a 9.5J 5.5 back space.... They don't fit....NICE
I measured an thought they'd fit - I lost 1/2" some where in my math.
Should have goe with the 5 back space Wheel vintiques recomend or even better go with a nice healthy 245/45/17s. Currently I've got a 7/16 spacer (on drums) and I can ony just detect something rubbing.
they stick out a little to far to look totaly right.
That being said, 275 will look perfect without the spacer when I mini tub. With the correct inset from the fender arch.
By the way my car is either built very differently or you guys with the same set up are not going around corners. I've got a Watts Link to limit side to side movement and I've only got 1/4-1/2" between the body and tire. Somthing doesn't add up...hmmmm
My 245/45/17 on 8J, 4.5BS rubs on the bolt securing the front fender to the body (behind the wheel) on full lock. 4.25"BS I think would have fixed this. Again the look is about right so I'll be changing the bolt to button head to get clearance. (fyi I'm running Wilwoods 12.19" discs up front)
Colt zantop- I measured twice, D'oh. 275 on 18 don't bulge as bad. oh well funds need to recover for the tubing, 4 link etc... then it'll look just fine.
whytry
04-12-2005, 02:51 PM
Do they make a 275/45/18? I have seen this in 17" but can't find it in 18... That is the size I would like to run in the interum.. Until I get everything else done...
Vince I haven't forgot about you....
