Results 1 to 20 of 22
04-06-2005 #1
Upper Control Arm Bushing Fell Out?
Hi, I was looking at my 67 Camaro's front suspension, trying to get an idea on how to lift the front end up. I've been looking over my car for a the past two weeks and to day I noticed that the passenger side upper A-arm is missing its front bolt and bushing off the shaft! So I've never did suspension before and was wondering if this is something I can fix or will I need something jurassic done? Like will I need to take the upper A-arm off and get someone to stuff a new bushing in? Also what parts will I need?
Thanks1967 Chevrolet Camaro 350/350
1962 Chevrolet Chevy II 400 194/PG
04-06-2005 #2
- Join Date
- Aug 2004
- Location
- Vancouver BC
- Posts
- 159
Scary. Make sure to torque ALL other bolts as if you/they missed one, there may be more loose. Dont be afraid to use blue loctite on suspension/steering bolts.
Originally Posted by TheRoaringEagle
Is it one of the large nuts that came off on the front of the A-arm cross shaft? Or one of the 2 bolts that hold the cross shaft to frame? What kind of bushings? If steel or poly you might be able to just stuff one in but if its rubber you are going to have to take it off and press it in.
04-06-2005 #3I'm pretty sure the bushings are all stock rubber. And the nut that came off is on the front of the A-Arm cross shaft, not on the frame. Can I replace it with a polyurthane bushing?
04-06-2005 #4
- Join Date
- Aug 2004
- Location
- Vancouver BC
- Posts
- 159
I wouldnt stick a poly bushing in there. Sounds like you are going to have to remove the a-arm and get a new bushing in there. I am a little suprised that the rubber has come out though. Its pretty tough stuff but with a nut/washer missing who knows what happened. Dont suppose you have a pic of the area? To replace your upper control arm you do not have to remove the lower arm and spring. You have to leave a jack stand under the lower control arm, then remove the upper. Make sure there is no spring pressure on the upper control arm as you remove the balljoint or else you may hurt/kill yourself.
04-06-2005 #5
