View Full Version : t56 question
khoult
10-05-2009, 02:04 PM
i have a lt1/t56. can i use it with my ls1 engine?
thanks.
jfaria78
10-05-2009, 03:42 PM
for sure you have to change the bellhousing, I also believe the input shaft is too long and that will have to be changed as well.
Contact Tyler at ATS, he has all the answers!
James
www.t56kit.com (http://www.t56kit.com)
Twentyover
10-05-2009, 04:04 PM
Could you put a spacer between the bell and the transmission? What about the differences in clutch actuation?
130fe
10-05-2009, 04:43 PM
Think you also have to change the mid plate and then get it shimmed correctly for the difference in length.
khoult
10-07-2009, 05:20 PM
i need more information about this swap before i begin looking for a ls1/t56. what parts are needed, how much will it cost, and how to do it?
thanks.
93Polo
10-07-2009, 06:13 PM
Yes the bellhousing, mid plate, and input shaft are all different on a LS1 T56.
Tyler would know of any other ideas on adapting the trans. A SBC/BBC bell housing will bolt to a LS1 but the flywheel is in different location, automatics have run adaptors.
