View Full Version : V10 stang......info
PT_79_TA_461
10-04-2009, 03:59 PM
i dono if this is a repo, but i was wondering if any of you guys know anything on this engine....its not even on WIKI..or in any other search..
http://www.youtube.com/watch?v=92qNG6syZkI
http://www.youtube.com/watch?v=m6eSBLY5pIA&feature=related
ANIMOSITY
10-04-2009, 05:18 PM
Yeah, that motor was a test mule for the updated Shelby Cobra concept that was built awhile back. Its a one-off motor with DOHC heads. The v10 in the truck is a SOHC . Basiclly they wrote that ford took a 5.4 DOHC motor and added to cylinders to it. Lat I heard is there are NO plan to release this motor.
What a shame I think that motor would make some viper owners sweat.
PT_79_TA_461
10-05-2009, 08:20 AM
wow, Fail on fords part for not bumping this engine into production...so menny application possibilitys...
.:Jimbo:.
10-05-2009, 10:40 PM
http://www.hotrod.com/featuredvehicles/hrdp_0401_1999_ford_mustang_gt/v10.html
Specs:
Engine
Type: 351ci odd-fire DOHC V-10
Block: Prototype 90-degree cast-aluminum
Bore/stroke: 3.552x3.543 inches
Crank: 4340 billet-steel
Connecting Rods: Stock '03 Cobra
Pistons: Stock '00 Mustang Cobra R forged aluminum
Cylinder Heads: Prototype 4V aluminum based on '00 Mustang Cobra R
Camshafts: Custom billet-steel with stock '00 Mustang Cobra R lobes
Valvetrain: Stock '00 Mustang Cobra R
Induction: Custom fabricated intake based on two '00 Mustang Cobra R lower manifolds, twin 70mm throttle-bodies, twin 80mm MAF sensors
Ignition: Two parallel EEC-V ECUs with separate cam and crankshaft sensors
Exhaust: Custom 5-into-3-into-1 tubular headers with merge collectors, custom 3-inch dual exhaust with X-pipe, four catalytic converters, four mufflers, and 211/42-inch tailpipes
Power (http://www.hotrod.com/featuredvehicles/hrdp_0401_1999_ford_mustang_gt/quick_inspection.html#): 432 hp, 401 lb-ft of torque (chassis dyno)
Built By: FoMoCo Powertrain Research and Advanced Engines
I suppose with their GT supercar needing only 8 cylinders, be it a retro throwback kinda thing or working with tried and trued parts from the bin (GT engine borrowed many bits from trucks under the ford umbrella), I can't see this engine showing up in anything anytime soon....
