View Full Version : nova q
vince72
04-05-2005, 03:51 PM
how everyone doing?
i have a question i cant get the gear box of by buddys 63 nova whats da trick?
thanks
04-05-2005, 11:20 PM
Hi Vince,
doing good here. Now you want to remove or find a box? Remove, pop the pitman arm(easier on car sometimes),disco the rag joint and undo the bolts to the frame.Becarefull on the last step, gravity usually takes over.
vince72
04-06-2005, 01:06 PM
well the front end is already apart so are the frame bolts. so i just need to remove the pitman arm and rag joints?
thanks for the reply
acadian
07-23-2006, 11:05 AM
remove the steering wheel,remove the steering column cover completely,
after that you can remove the steering box after removing the pitman arm of course.
the steering box of a 1962-1966 extend up to the steering wheel due to a very long shaft that is part of the box.
hope it clears the issue you are having with its removal.
