View Full Version : Dual relocation kit
el-camino
04-05-2005, 12:47 PM
Dual relocation kit
hi,
i have a dual oil filter relocation kit. this kit has on each side a "IN" and "OUT". on one side comes the hoses from the engine. on the other side i want to connect hoses to a oil cooler, will this work ?
thanks
gen3bu
04-05-2005, 06:05 PM
it will work fine. all you have to do is get the oil filter adapter, route one hose from the 'out' port at the engine to the 'in' port on the new filter adapter. then route a line from the 'out' port at the new filter adapter to the cooler. and finally back to the engine filter adapter 'in' port.
good luck
kevin
gmachinz
04-05-2005, 07:37 PM
Make sure you are using at least -10AN fittings/hoses for proper oil flow. If you need advice or ideas with fittings, email me and I can help you out. I mounted my dual kit right under the front bumper support on my '78 Monte Carlo. -Jabin
