View Full Version : Mickey thompson s/r tires
chapster
09-27-2009, 04:08 PM
MT radials 20" diameter 18" wide require a 15" wide wheel. MT recomends a 13" or 14" wheel for there new 15" wide tire. Does this math make sence to anyone? why is it ok for 1.5" excess for one but only a 1/2" excess for the other.
Would you atempt to run the 15" wide tire on a 12" wide wheel (1.5 excess both sides)?
Any advise?
alowerlevel
09-27-2009, 06:43 PM
Try asking here http://www.yellowbullet.com/forum/forumdisplay.php?f=107
chapster
09-28-2009, 01:17 PM
thanks, I will try there.
Anyone else with a opinion?
astroracer
09-29-2009, 02:19 AM
What is the aspect ratio difference between the two? A taller sidewall can run a narrower rim because the sidewall has the "room" to move. A shorter aspect ratio tire needs a rim closer to the actual sidewall width because the sidewall can't reach the narrower width and maintain proper bead seating under load.
MAS
chapster
09-29-2009, 02:42 PM
I totally agree,
My understanding is that mickey thomson tires don't measure on a standard aspect ratio theory.
both tires are for 20" diameter wheels and both wheels are 29" in outside diameter which means same sidewall height????
astroracer
09-29-2009, 03:02 PM
[QUOTE=chapster;579980]I totally agree,
My understanding is that mickey thomson tires don't measure on a standard aspect ratio theory.QUOTE]
Ah, I see. Looking at it from that respect I would surmise the "recommended" width is based on what is readily available for rim sizes. A 20 x 15" rim is (sic) a standard size.... Going wider will be more expensive which would probably drive away potential customers.
As for running the 15" wide tire on a 12" inch rim. Go for it. Isn't going to hurt a thing. Manufacturers usually allow for an inch either way (narrower or wider) and the extra tire overhang will protect the rims from curbing.
MAS
