View Full Version : Wheel/tire combo front of camaro with sppedtech suspension
Scooby
09-19-2009, 03:14 PM
Wondering if it'd be possible to fit something larger then my current 245/40/18 on 18X10 wheels with 4.75 inch BS and Wilwood Superlite 6 W/ 13" rotors. Have Speedtech upper and lower control arms, Ridetech 2 inch drop spindle, and stock subframe. Maybe a 255 tire? or a 18X9 with a 275 tire with more Backspacing
Scooby
09-19-2009, 03:15 PM
if not I'll eventually upgrade to the whole speed tech front subframe and pray that makes my wider tire dreams a possibility
Scooby
as of now tires almost rub on outside so don't think a 255 is possible without more BS
killer69
09-20-2009, 11:08 AM
your probably right.
18x10 works with the hi clearance arms but they only work on the complete sub. the issue will be the drop spindle/ steering arm when you add back space so have a look at the outer tie rod end to determine how much mor back space you can add.
eville
09-20-2009, 12:16 PM
I don't think you have an 18x10 wheel on the front. There is no way an 18x10 with 4.75 BS would fit on the front. And I don't think a 245 would fit on a 10 either. I think you have an 18x8.
