Results 1 to 18 of 18
09-17-2009 #1
- Join Date
- Aug 2009
- Posts
- 14
Will 295/35/18s on 10s fit inside a stock 71 Camaro?
I've got a 71Z that is lowered 2" otherwise a stock leaf spring set up that I want to stuff the biggest wheel/tire combo in and am looking for some guys that have actually accomplished putting the 295/30 10" rim combo in an unmodified wheel well. I've been told that a 275/40 on a 9" or 9.5"rim is a sure fit but I would like to get a wider tire in there if I could. It's an original Z28/RS that I don't want to chance cracking the paint by rolling the lip on the 1/4.
09-17-2009 #2
- Join Date
- Jan 2008
- Location
- pnw oregon
- Posts
- 27
i'm running 285/40/18 on a 9.5" wheel on my 73. it's lowered 2".
on hard corners it would rub just a little bit on the rear seat belt hump but it clears the 1/4 fine. they were 5.75" backspace if i remember right.
09-18-2009 #3
- Join Date
- Aug 2009
- Posts
- 14
evo462; do you think you'd have enough room to run the 295/35 on 10s combo or would you have to pound down the seat belt hump and roll or cut the lips? Do you know the cross section of your mounted tire? How much room do you have between the sidewall and the 1/4 lip? Thanks
09-18-2009 #4
- Join Date
- Oct 2004
- Location
- stanwood, wa
- Posts
- 324
If i remember right you have to roll the fender lip and your measurments on the wheels will need to be right on. The seat belt himp should be fine until you go to 11's
09-18-2009 #5295/50/15 old school
Gav
69 camaro rs/ss clone.
09-18-2009 #6
- Join Date
- Jan 2008
- Location
- pnw oregon
- Posts
- 27
i measured my 285 tire. at the widest point in the sidewall it's approx. 11 1/8". i've got approx. 3/8" from sidewall to inside of the lip on the 1/4. i think a 295 would be a tight fit on a lowered car but i'm sure you could make it work.
09-21-2009 #7
- Join Date
- Oct 2006
- Location
- Corona, CA
- Posts
- 1,948
