View Full Version : 70 Chevelle w/ Rushforth Whiplashes
70chevelle406
09-12-2009, 09:10 PM
Picked them up today, called in sick to work and mounted them up.
https://static1.pt-content.com/images/pt/2009/09/DSCF30854-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF30863-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF30911-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF31061-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3107-1.jpg
70chevelle406
09-12-2009, 09:15 PM
a few more...
https://static1.pt-content.com/images/pt/2009/09/DSCF3108-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3112-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3123-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3125-1.jpg
70chevelle406
09-12-2009, 09:55 PM
The rear sits a little high. Anyone know where to get any 3" lowering springs. 1.3" Eibach springs are whats in there now.
Vince
BaddestBuick
09-12-2009, 10:01 PM
Nice rims and velle, OPG has 3" lowering springs
brans72
09-13-2009, 06:11 AM
Looking good. I have had mine a year now still in garage waiting to see pavement. Glad to see people looking outside the box on a 7 spoke wheel finally!
JayR
09-13-2009, 08:09 AM
Looking good, Vince! I know you were agonizing over your decision but they look killer on there so hopefully, that calmed your second guessing.
Don't buy springs, just cut a little bit off your Eibachs with a cut-off wheel or a chop saw. When cutting performance springs, keep in mind that 1" of spring height when measured sitting on the bench unloaded usually equals a 2" drop and don't count on much settling. You already have a high quality set of springs, just trim them a little.
Tucks69
09-13-2009, 08:30 AM
Looks Good!! Can,t wait for my Rushforths to come in. Only my car project has just started.
MIGOAT
09-13-2009, 08:56 AM
love that A body. Sweet wheels!!
70chevelle406
09-13-2009, 10:33 AM
Thanks Jay, unfortunately the rear springs are pigtailed on both ends, so I wont be able to cut them. I swapped them out yesterday w/ some worn out stock springs, and the stockies actually sit 1 inch higher. Once I find a solution for the rear, the stance will be perfect.
70chevelle406
Those spring are for newer models I believe.
SUNK69
09-13-2009, 11:39 AM
Your car is lookin great, nice choice. I have been completely satisfied with my Rushforths also.
The WidowMaker
09-13-2009, 02:44 PM
run the speedway adjusters and the shorter springs. that was what i had before i went insane and basically backhalved my finished frame and suspension.
just remember that stance is EVERYTHING. it looks great now, but it would be insane about 2" lower.
the wheels are friggin sick!!!!!
Tim
70chevelle406
09-13-2009, 02:55 PM
Tim
Where would I get those?
BaddestBuick
09-13-2009, 03:47 PM
No theyre for your car 67-72 Chevelle pnC990103, this is how they left mine, I should have got the 2 inchers
https://static1.pt-content.com/images/pt/2009/04/asdfb-1.jpg
70chevelle406
09-13-2009, 04:09 PM
Wow. that looks awesome. Ill look into these. Do you have any issues with the 3 inch drop? Why do you wish you went for 2"
Vince
BaddestBuick
09-13-2009, 04:22 PM
Vince
Thank you, no issues, you just have to have the right backspacing and look underneath the wheel opening to make sure the with the drop you wont rub anywhere
I shoulda gotten 2" because the rear sits a little lower than the front, I like the stance even or the front lower then the back thats all.
Ralph LoGrasso
09-13-2009, 04:25 PM
The wheels look great!
70chevelle406
09-13-2009, 04:57 PM
Thanks guys, for all the nice comments!
CliffS
09-14-2009, 02:59 AM
killer look. Is that a 18-20 combo? What size rims?
Like to hear your review on the NT05.
70chevelle406
09-14-2009, 07:33 AM
19/20 combo. I cant really give a review yet as I only have about 4 miles on them. Just up and down the street to make sure there were no rubbing issues.
Vince
buickfunnycar.com
09-14-2009, 08:38 AM
Now that's the spirit...lol!
Looking good,welcome to the family.:yum:
CliffS
09-14-2009, 09:03 AM
Thanks Vince, is the 20 a 10" wide rim?
John Wright
09-14-2009, 09:07 AM
Wheels look good!
tones2SS
09-14-2009, 11:22 AM
Looking good!!
DriverzInc
09-14-2009, 12:04 PM
Yup, I've run their 3" springs in the past too, on our 67 chevelle, and they were bitchin....
Wheels look great on the car Vince.
Vince picked up the wheels from my house on Saturday morning after we stayed late at the shop Friday night to make sure they were mounted and balanced and ready for him to pick up. I took them home since my house is closer to San Diego where Vince is from. Looks like the clearances, and the tire sizes worked out perfectly (which of course is the Driverz way!). And other companies say you can't put a 10" wheel back there? They obviously don't know what they are talking about!
70chevelle406
09-14-2009, 03:13 PM
The specs on the rims and tires are as follows:
Front:19x8 BS 5" Pad 1.5
Tires: 245/40/19 NTO5
Rear: 20x10 BS 5.75" Pad 1.0
Tires 275/40/20 NTO5
I actually went out today with them, as I ust hooked up passing gear last night. All I have to say is WOW. These tires really hook up, and are super gummy. I am not a huge fan of the pattern but, oh well.
Good Call Jon on the tires as well as the measurements on the rims. Once I install the 3" drop springs I think I might be able to fit a wider tire in the rear, as it would clear the tail pipes.
Vince
JT_67Tempest
09-14-2009, 08:18 PM
The wheels look awesome!!! I have the NT05's on my ride and they handled great on the Autox. OPG out in Huntington Beach carry the lowering springs you need.
Scooby
09-14-2009, 09:18 PM
Keep in mind if you cut your springs it changes the spring rate. My friend used a spring compressor and heated the coil on his M3 to lower it. Just kept them compressed with heat for about 5 minutes, heating 3 or four of the coils.
JayR
09-15-2009, 07:11 AM
That will also change the spring rate and seems more likely to ruin the spring.
6'9"Witha69
09-15-2009, 07:21 AM
One of the absolute worst ways to lower a car.
70chevelle406
09-15-2009, 08:13 AM
I am not going to cut the springs. As I said in my previous post, the springs are pigtailed (both ends) in the rear, so it is impossible to cut them and keep them from falling out from under the car. I plan on going with OPG's lowering springs. I just don't know if Im gonna go 2" or 3".
buickfunnycar.com
09-15-2009, 09:00 AM
Go 3",you'll be fine...
The WidowMaker
09-15-2009, 09:22 AM
3" is my vote... and remember that opg is now in seal beach. their new shop is MUCH larger.
good job jon. fitment looks awesome. i hate when people tuck the tires in to get them to fit. these look like they are pushed out towards the quarter perfect.
Tim
70chevelle406
09-22-2009, 04:51 PM
Went to LA today for a physical, and dropped by OPG to pick up some rear springs. The general plan was to order both the 2" and 3" and compare the difference. Since the 2" were out of stock I just picked up the 3" and installed them right when I got home. So I now have a set of Eibach 1.3" Rear lowering springs for sale if anyone is interested, PM me.
Heres the difference: 1" springs compared to the 3"
https://static1.pt-content.com/images/pt/2009/09/IMG_0482-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3149-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3150-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3151-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3155-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3154-1.jpg
https://static1.pt-content.com/images/pt/2009/09/DSCF3156-1.jpg
bigpower
09-22-2009, 05:05 PM
what size springs on the front? I'm working on what to do to my 72 chevelle and you just helped me decide . 3in in the back . stance looks good
GRNOVA
09-22-2009, 05:23 PM
That thing looks Bada$$. Those rims look killer.Nice chioce.
69496
09-22-2009, 05:48 PM
Did you know what the spring rate is for those 3" drop springs you got?
70chevelle406
09-22-2009, 06:15 PM
Eibach Pro Kit 1.3" in front
I have no clue what the spring rate is on the rear. They are Jamco springs sold exclusively by OPG.
Vince
Idesigner
09-22-2009, 07:45 PM
Wow, Vince.
It is really amazing how lowering the car really changes the look and appeal of the car. Looks great!
Now you have me hoping i am going to go with the right drop on my car. When i put my new wheels on I have 3inch OPG drop springs for the front and the 2inch OPG for the rear. I hope the 3inch fronts are not too low!
How is your front clearance?
JayR
09-22-2009, 08:38 PM
Wheels and stance are everything! What a difference 2" makes!
Nice job, Vince!
70chevelle406
09-23-2009, 01:08 PM
Wow, Vince.
Front clearance is good. I don't think I could go any lower. It would more then likely rub on the fenders when turning. I also think it depends on the wheel and tire size as well. The buick in the earlier post has 19" rear and it looks slammed way lower then mine.
USAZR1
09-23-2009, 01:58 PM
+1000 Vince's car looks killer now,doesn't it?
buickfunnycar.com
09-23-2009, 03:42 PM
What a difference 2" makes..!
Hmm...I could comment...must resist,lol.
Seriously,looks like a whole different car.:yum:
muthstryker
09-25-2009, 07:36 PM
lol you caught it too eh...
The car looks 10x better lowered, looks really good now!
SpinOne
09-26-2009, 10:40 PM
It's been said before and it true. Wheels and Stance are everything. A car could be primered or freshly painted, but if it doesn't have nice wheels with the proper stance it doesn't have that 'Sic A$$' look. instead, it's just another car.
USAZR1
09-27-2009, 01:27 PM
Truer words were never spoken.
4086D9
09-29-2009, 10:01 PM
Looks killer man!!
70chevelle406
10-13-2009, 07:35 PM
I got new wheels today.
https://static1.pt-content.com/images/pt/2009/10/DSCF3162-1.jpg
https://static1.pt-content.com/images/pt/2009/10/DSCF3171-1.jpg
https://static1.pt-content.com/images/pt/2009/10/DSCF3173-1.jpg
69496
10-13-2009, 07:39 PM
Im confused. Didn't you just get the whiplash wheels or are you playing with us.. Or do you really have enough money to buy both sets.... how bout a loan:idea:
70chevelle406
10-13-2009, 07:45 PM
manufacturer defect on the whiplash. no more extra cash sorry!
69496
10-13-2009, 08:16 PM
I love both of those. I got superspokes myself. But I was stuck between superspoke, whiplash and that last one which I suddenly forgot what it is called. I love all three of them and every picture I see of each makes me want one. I love the entire Rushforth line and now with the NewGen line coming out I have a second favorite. I know I sound like a hidden add for Driverz Inc and Rushforth but I like their wheels and Driverz Inc is great to deal with. Just my experience and taste.
DriverzInc
10-13-2009, 10:10 PM
Hey thanks for the props bud. We're working hard to try and make each and every customer happy, and be as helpful as possible, and its good to hear positive feed back like that.
1badchevelle
10-14-2009, 08:24 AM
You are killing me I just ordered some rated x but these look killer. What are the spec's
70chevelle406
10-14-2009, 09:45 AM
19x8 front w/ 5" backspace and 20x10 Rear w/5.75 backspace.
1badchevelle
10-14-2009, 09:52 AM
do you have a 4" lip? and how much space do you have between the wheel and the inner fender?
Idesigner
10-14-2009, 12:34 PM
Vince, If you don't mind sharing why did you change wheel designs?
70chevelle406
10-14-2009, 12:55 PM
yes 4" in rear and almost 3" up front. the rear tucks in very nice w/ no clearance issues. The front also has no clearance issues, but it could come down just a tad if I remove the hex bolts in the inner fender. Jon did an amazing job with fitment sizes. I can barely get my fingers around the rear wheel when it is flat on the ground.
I went with the 5 spoke because I felt it suited the car much better.
muthstryker
10-14-2009, 05:34 PM
that looks really good, almost better then the other ones.
ed1le
10-22-2009, 01:00 PM
Killer stance & wheel combo! I have the Eibach's on my 'lark now and want to bring the rear down but was hesitant to use the 3" springs...you solved that I think!
JustinB
10-22-2009, 02:52 PM
LiveWires look so much better on that car than the Whiplash. The polished lip and 5 spoke just bring the whole car together. Jon really knows what he is talking about as far as what looks good on what. Good choice and well done.
Blitz
12-02-2009, 09:40 PM
Can we get more pics? :smoke:
70chevelle406
12-03-2009, 09:54 AM
WHat would you like to see?
Blitz
12-03-2009, 04:39 PM
Just wanted to see more pics of the car with the Livewires. After seeing some brushed editions in a recent magazine (forgot which one...red car though), those have quickly risen into the top 3 dream wheels for me and my 65.
If you can, I'd love to see some different side shots and a couple 3/4 angle shots at least.
70chevelle406
12-23-2009, 03:32 PM
I am without some panels of the car at the moment as they are getting molded for carbon, so i will snap some new shots when those get back to me. Sorry for the delay!
Vince
PRRC
12-23-2009, 06:55 PM
Check our website we have a great image gallery.
1badchevelle
12-23-2009, 07:39 PM
Vince good to hear you were chosen for the c/f.
bgray
12-23-2009, 08:27 PM
love your side markers
70chevelle406
12-23-2009, 09:55 PM
Thank You. I just can't wait to get the panels back. Anxious...
Yea Matt and Tyler were real cool. they drove down from LA and picked up the hood, trunk, and a-pillars right out of my driveway.
shoe4hire
12-28-2009, 08:49 AM
Killer look
FroopieLoopies
02-12-2010, 08:10 AM
needs to be lowered a bit, but besides that its looking really good man
maverick7878
02-19-2010, 09:46 AM
You have to post pics of the CARBON FIBER panels as soon as you can!!!
